Synology Update Lost Media Server
Posted by: Mike-B on 02 February 2018
Synology update  DSM 6.1.5-15254 is in the hopper ready to install or if you are set for auto-update,  its been done.    Problem I had with mine is it 'lost' Media Server.    Its still there, the app works as normal, its just not showing as an icon on the Synology GUI (computer screen) Main Menu.
The fix is simples,  go to Main Menu, open Package Centre, open Installed, open Media Server, touch the Action button & then touch Stop.  Let it complete its stop process & then touch Run.   The Media Server icon will be back on the Main Menu.
Not sure if it does the same for Minimserver.
Posted on: 02 February 2018 by kend
Thanks for the heads up. I now know to look out for this when I do the install at the weekend.
Posted on: 02 February 2018 by Huge
Didn't cause any issue for me.
