NAC92 Phono Boards
Posted by: GrahamK1980 on 04 February 2018
Hi Guys/Girls
Just bought a NAC92, Flatcap and NAP90.  It has phono boards installed, can somebody tell me if these are MC or MM
Also looking to get a bit more power, can I get another NAP90 and bridge them? Don't know if this is possible with Naim Power Amps
Many thanks
Graham
NAC92
Caption
Posted on: 04 February 2018 by Richard Dane
Last question first:  No, you can't bridge them. You can run active with suitable speakers - Naim, Linn etc.. although you'll need an IXO active crossover as well.
If you reallyt need more power then consider a different amp.
As for the boards, NA522 = MM.  NA523 = MC (either S, K, or E/R)
Posted on: 04 February 2018 by GrahamK1980
Thanks Richard.
