App needed for USB drive
Posted by: Japtimscarlet on 09 February 2018
Hi
I have a 250 gb usb solid state harddrive that I can plug into my 272 front panel to play tunes
It doesn't show the titles properly or art work at all
When streaming from my Nas drive it works ok
I assume this is because I don't have a "roon?" Type program on the usb drive? Is there a free program that I can just dump on the drive that will sort this out so it all works ok though the naim app?
The Nas came pre installed with a program so I didn't have to worry about it
Any help appreciated
Posted on: 09 February 2018 by Mike-B
The USB drive is just like you see,  the NAS has its media server UPnP software installed,  the USB doesn’t.    I understand Roon will fix it,  but not tried it myself (all my music is on NAS or internet, so no point)
Posted on: 09 February 2018 by ChrisSU
If you can plug the USB drive into a NAS or computer, and point your media server at it, you should be able to see its content complete with metadata.
Posted on: 09 February 2018 by hungryhalibut
Or simply copy the music to the nas.
USB into NAS or PC works OK,  but its not the players front panel USB port.
Posted on: 09 February 2018 by Japtimscarlet
Thanks Mike B
That's exactly it ..I have all the music on Nas ..but wanted to be able to have the same features but direct plugged in the 272
Is there a free software item that will package the music in a more accessible way....it sounds great as is ..but looks crap on the naim app
I'm not aware of any software that can be used to make the USB replay less clunky,  that said I've not looked that hard as I rarely play anything on the USB port.
I used it in the past as an SQ benchmark, USB is as good as the players SQ gets,  but once I'd determined my NAS via the all wired ethernet & switch sounded just as good,  I was done.
Posted on: 09 February 2018 by Huge
When you access a file through the USB port that is EXACTLY what you are doing - access the file.  What you see through the UI is the file names in the file system.
On the other hand UPnP streaming from a NAS drive is provide by a server (running on the CPU of the NAS) that indexes the files to be searched via a database.  To find a track (data) to be streamed via UPnP you look up the metadata (Artist/Album/Track name etc.) in the database rather than using the file name.  The Media Server then finds the right file for you.
Unlike a NAS drive, a USB stick doesn't have anything like a CPU that can run a database application for you, so you have to stick to the file names.
Ahh ok huge
Was hoping it was just a case of throwing a program on the drive to improve things...but if this is a no go ...I will have to make the best of my Nas with the great posts that are ongoing at the moment
Cheers all
