pmc twenty 26
Posted by: Johnny5 on 10 February 2018
Do the pmc twenty 26 need a large space for use..
Never heard the 20 26 but from comments in the forum i think they need a better tweeter. Anyway that s my impression based on comments here.
What about the Twenty5 26 the latest model
Same tweeter.
I have the Twenty 5 23 they are great but I got the new nac 282 and nap 250 dr and feel the 23 are outclassed now with the new amp I did have the supernait before amp change and the 23 where great with supernait.
Since you feel the 23 are outclassed by the 282 and since the 26 uses the same tweeter like the 23 you have your answer. look elsewhere.
the speakers are difference the 26 has the 50mm dome mid- range I just have not heard it.
leni v posted:Never heard the 20 26 but from comments in the forum i think they need a better tweeter. Anyway that s my impression based on comments here.
I love these uninformed throw away misleading comments.
There are many PMC Twenty and Twenty5 users on the forum. About two who auditioned them found the characteristics of the tweeter not to their taste. I'd not form any opinion on that or in fact pay any attention to speaker recomnendations on the forum in general. Since no one has your room or ears and speakers are a huge matter of personal taste, assuming you might lije or duslike a pair of speakers based on others comments is like deciding you don't like asparagus because your friend says it taste horrible.
@JHONNY5 (is Alive!) you may be surprised. It may be that the PMC character is not for you. But if you are worried about the cost disparity between the Twenty5.23 and the amplification chain, don't be. I originally bought the older Twenty.23 to go with a 282/HCdr/250.2 all at the same time. Started auditioning the same speakers with a SuperUniti but they responded excellently to each upgrade, so I stuck with them when placing the final order. Then adding a SCdr to the 282 and they let through the improvement instantly.
After moving the power amp to a 250dr, I took an opportunity to get Twenty5.23 for an amazing price. I've mentioned many times here that I budgeted for Twenty5.26 for that upgrade but went with the smaller 23s because the 26s can be demanding of room size and I didn't feel like I should blow GBP6k just because I could. In my 8x7m room, the Twenty5.23s are almost too much. There is no way I could have gotten away with 26s in this (already largeish) room.
If the OP cannot audition the speakers, and is not already familiar with a similarly sized PMC speaker, I'd not risk buying on a punt. Better to wait until audition chances arise, which, if you live miles from a dealer (or even with no dealer in your country) could take a year or more I realise.
Get a home dem, I love my 25.26 in a room 6 by 7 metres with a Nap300 driving them. The one consistent theme on the forum is speakers are a very personal taste, and you really need a home demo.
I agree, take no notice of such throwaway comments. I auditioned the 20.26 and thought they sounded amazing from top to bottom. I would have kept them if my room was big enough to cope. They were way too bass heavy for my modest room 4.2m X 4m. A very special speaker.
If your room is big enough then I would recommend an audition.
I eventually settled with ATC scm40 actives, still just a tad too much bass for my room but acceptable. Scm19 were a perfect fit room-wise.
By all means please try, but depending on where you have come from you might find the tweeter relatively a little coarse or unresolving... I did .. disappointingly so... I tried on both Statement and 252 based systems.. it also depends on the music you like.. I like choral music which really needs a smooth detailed Hf driver, not a crunchy exciting one, and perhaps therefore they just weren’t for me
OK thanks I have decided to get a sc dr before I do anything else I do like the Twenty 5 23 and see what happened.
looking at pmc web page the fact 8 will fit any size room they claim in the brochure. ...might be a better option than the twenty 5 26.I will need to hear the facts because they have a difference sound looking at some of the forums.
leni v posted:Same tweeter.
Not true. It has a different model number and even visually is different, having a perforated grille over the dome. Even if that is the only difference, it will have an effect on the sound.
Have you heard the fact 8?
If you’re contemplating buying 20-26 or 25-26 new, it may be worth considering instead a secondhand Fact 12, which is a very much better speaker, and slightly tweakable to better match the room. I’ve seen them as low as £8k ex dem in UK, and a pair was advertised only a week or so ago on a German site for something like €6.5k.
yes but that would mean changing the amp to at least nap 300
Johnny5 posted:looking at pmc web page the fact 8 will fit any size room they claim in the brochure. ...might be a better option than the twenty 5 26.I will need to hear the facts because they have a difference sound looking at some of the forums.
Something is ringing a bell. Was it you who had the recent thread on Fact 8, and your dealer doesn’t stock them for you to hear? If that recollection is right, someone did suggest that it would be worth speaking to the dealer who may be able to obtain one for the purpose of audition. My understanding , though i haven’t compared, is that Fact 8 doesn’t do as deep bass as 20-26, but is better above that. Fact 12 is better than 20-26 all round - more refined I think would be my summary from when I heard them both a couple of years ago.
Of course, the only way of being certain is hearing, in an environment as close to your own room as possible: I heard the F12 in two different rooms, and in one the soundstage seemed rather compressed, the other not at all, but apart from that they sounded great in both. The first room, purely from mental image, was maybe 20x12 feet, firing across, with speakers some way out from wall and listening position very close to wall, and the second maybe 15x18 feet firing down the length, speakers and sofa both well out from walls.
yes that was me my dealer does not stock fact range but I will be asking them to ask pmc to send a demo for home demo as I already bought pmc 23 nac 282 nap 250 all new from my dealer.
Same seas sonolex 27 mm soft dome tweeter from entry level 2000 GBP 21 up to the 7000 GBP 26.
leni v posted:Same seas sonolex 27 mm soft dome tweeter from entry level 2000 GBP 21 up to the 7000 GBP 26.
I don’t disagree: however, your response saying “same tweeter” was when the OP suggested 25-26 in place of 20-26, following adverse comments about the tweeter of the 20-26. The 25 series all share the same tweeter, as indeed do the 20series as you noted, but the 25 series tweeter is not the same unit as that of the 20 series, having been improved in some way.
OK
Innocent Bystander posted:leni v posted:Same seas sonolex 27 mm soft dome tweeter from entry level 2000 GBP 21 up to the 7000 GBP 26.
Indeed. Different screws. Different mesh coating and shape. And the Twenty5 series crossover makes the tweeter work almost as a mid-high driver.
Should also point out that in general, tweeters are often (but not always) chosen as the one constant in most speaker ranges.
I would expect in a7 k speaker better components then in a 2-3k speaker.
leni v posted:I would expect in a7 k speaker better components then in a 2-3k speaker.
There are many approaches to speakers design, in the case of PMC’s transmission line based design, the cabinet material construction is a critical factor and contributor to cost. So, comparing specs of the drivers is a waste of time.
For the OP, I really hope you get to listen to as many speakers as you can , PMC as well as others. You are not going to ge very much from forums or revie others than forming a short list for home demos.
BTW, I contacted PMC (not the dealer).
The biggest cost (and size) in a speaker is getting the bass right, and that is what generally improves up the range, as certainly is te case with PMC and their transmission line approach, of course costing more in the process. At some point in the range as the bass driver gets better at bass it becomes better to use a separate midrange unit, that also allowing improvement of the mid, and that, with the associated increase in complexity of the crossover, also adds to the cost.
