Naim Sleeves / Case
Posted by: Alex Horky on 17 February 2018
Hi,
I would like to buy some new sleeves, size like nap200/ nac282 ... are those enclosures are available anywhere?
Alex
Occasionally you see Naim parts available in the flea pit but no I shouldn’t think you can just buy them.
Lindsay
Maybe have a chat with your local dealer or alternatively email Naim direct and ask the question.
Are you asking if you can get Naim to replace the sleeves on your equipment - in which case the answer is yes, it’s something you sort out via your dealer - or whether you can buy cases that look like Naim cases, for some sort of DIY project?
Hi,
I will need them for diy some amps... not naim but those extruded sleeves are or should be cheep...
In which case, Naim won’t supply them. Maybe someone knows where you could get some.
You would need to source secondhand from the usual places. Note that Naim will not supply unless a bit of kit needs a replacement. Also note that DIY discussion falls firmly outside of forum AUP. Thanks.
