Spotify connect and podcasts
Posted by: Babymech on 19 February 2018
Hi,
I just started to get set up with my Naim Mu-So and am trying out Spotify Connect. Oddly enough it works fine to stream music via Spotify Connect, but I'm not able to stream podcasts. Whenever I'm streaming music, my Naim Mu-So shows up among available devices, but when I start playing a podcast via Spotify, I'm told I can't stream to the Mu-So as long as I'm playing that content. Does anybody have an explanation why this might be - is it because of the length of the streamed files, or some difference in encoding? I also have two Audio Pro Addon speakers on the same  network, and they work fine to stream both music and podcasts, so there's something specific about the Mu-So that blocks podcasts... any suggestions?
Thanks!
Posted on: 19 February 2018 by RadebeR
I just did a quick google for "Spotify Connect Podcast".   Top hit.... Spotify Community page bemoaning the fact that Spotify does not support podcasts via Spotify Connect. It was updated in January 2018 to say that the idea/issue didn't generate enough "kudos" to be taken forwards.
Forgive me... some more googling suggests Spotify Connect does support podcasts.  I don't know how to delete my previous post.
Posted on: 19 February 2018 by Babymech
No worries - I found that community page myself and was mightily confused, since I can obviously stream podcasts from Spotify Connect , just not to my Mu-So. I guess that's why it got so few 'kudos' - it's not a problem for everyone. Either it's my Mu-So that's limited, or it's my Audio Pro that's exceptional - will try it with Sonos and Bose over time, but for now I appreciate all help and attempts at help!
I'll gladly test on my Musos and report back when I get home this evening.
Thanks - that would help me find out if there's some software / firmware update my Mu-So is lacking. I've now confirmed that it works fine to stream podcasts to Audio Pro devices and to Bose Soundtouch devices, so the question remains why I can't get it to work with my Mu-So. I've sent a question to the Naim support team and they've just told me that they have no problem streaming music via Spotify Connect... which isn't what I asked. If you try streaming a podcast, let me know how it works out!
Just tested a few Spotify podcasts with my Muso...I get exactly the same result as you... Can't play podcast content via Spotify Connect.
Further to previous post, I also tried playing Spotify podcasts on my (Naim) Uniti Atom via Spotify Connect and they work fine.   It's clear from the device list in the Spotify app that my two Musos are greyed out (with the message "can't play this right now") whereas the Uniti Atom appears and plays as I would expect.
So this looks like a Muso-specific issue.  Definitely worth emailing/calling Naim to report the issue or at least get an explanation.
Posted on: 20 February 2018 by Babymech
Thanks - I also got confirmation that it's not a Spotify issue, and your info hammers that home. Interestingly, Naim seemed completely unaware of the issue; I originally thought this was a conscious choice on their part, for whatever reason, but it doesn't appear that way. They said they would look into it and get back to me.
Posted on: 20 February 2018 by RadebeR
Great news.  I'd be keen to know how it turns out (I only tend to podcast on the move) so please update the thread when you hear back from Naim.
