SBL - SPEAKER CONNECTION
Posted by: m.paul taylor on 21 February 2018
Do SBLS take banana plugs/.
Posted on: 21 February 2018 by james n
Yes. They are just standard 4mm sockets. I'd use the Naim plugs if possible as they provide a bit of strain relief due to the plastic housing.
Posted on: 21 February 2018 by m.paul taylor
Thanks James
Posted on: 21 February 2018 by Richard Dane
I would second the use of Naim SA8 speaker connectors.  They will mate perfectly with the sockets on your SBLs
