Tidal problem with my new iPad
Posted by: badger1963 on 21 February 2018
I hope someone can help. I have just bought a new iPad my old one getting on a bit. So I downloaded the naim app on my new iPad and ran through the usual finding rooms process. The iPad found my 272 no problems at all. I can queue and stream CD rips from my unitiserve just like my old iPad so all good so far. When I click on tidal the naim app on my new iPad finds tidal absolutely fine. I can even see my saved albums. But if I try and queue something from tidal it just hangs. Nothing gets queued. I can still queue tidal from the app on my old iPad, but tidal won’t queue from my new iPad. To my non technical mind both iPads are simply acting as a remote control, so I can’t understand why tidal will queue and function correctly from a 6 year old iPad, but not a brand new one. Any ideas?
Posted on: 21 February 2018 by Mercky
Sounds like you may not be signed in to Tidal on your new pad, go to settings and check account log in settings etc
Posted on: 21 February 2018 by badger1963
Thanks mercky. In fact your suggestion made me try logging out and logging back into tidal again. Very strange, although the app seemed to say I was already logged in, logging out and going back in did the trick. So mission accomplished. Problem solved. Appreciate your reply.
