iPad to 72
Posted by: Paper Plane on 24 February 2018
Is it possible?
Posted on: 24 February 2018 by james n
Steve - If your IPAD has a 3.5mm headphone socket then get yourself a 3.5mm to DIN cable (Flashback will sell you one for around £20). What are you wanting to do with it ?
Posted on: 24 February 2018 by Paper Plane
Listen to some different radio stations.
Thanks for the tip. Which input should I use? The 'spare' tape one?
Hi Steve - Yes - any of the line level inputs you have free will work.
 Thanks!
