Upgraded 250DR is on its way
Posted by: achique99 on 05 March 2018
Hi all,
I am getting a NAP 250 DR which is expected to reach me either by this week or next week to replace NAP 155XS in my active system paired with NAP 200. Would like to have your best suggestion which rack the power amp should be placed at. Should I place both the power amp in the middle rack below the Snaxo and 282? Or remains where they are now. With the current setup, there is only 1 empty shelf in the middle rack between the crossover and Napsc (please ignore the 4 empty tables as I illustrates below).
Later, the 250DR will be powering the HF tweeter while the 200 for the LF woofer. Also to add that, FCXS is powering both stageline and CDP while, 2 HCDRs are powering Snaxo and 282 respectively. I am also thinking to place the stageline next to the Snaxo as to shorten the distance and to ease the cable connection between the two equipment as they are nearly 1 meter apart now.
Am I following the brain and brawn concept here? Would love to hear your comments and benefit guys. Thank you.
Cheers, Nasa
