Supernait 2 vs Uniti Nova
Posted by: Sharon Kabir on 25 February 2018
Hi
I just wanted to know. Is there a difference quality sound ? Very very debating .
Both the same power output
Sharon
There most certainly is!
So has NAP 250 ![]()
What is the end-game system that you’re planning? A one box solution or many, upgradable boxes?
I had a Nova and changed it for the NDX/Supernait2 and the latter was far superior in my opinion. Lower noise floor was what really stood out to me. How much of that is the NDX I don't know
Did you compare the ndx/sn2 to the 272/250?
MangoMonkey posted:Did you compare the ndx/sn2 to the 272/250?
Hi Mango
No I didn't, I had a couple of faulty Novas in a row and my dealer had an ex demo NDX/Supernait2 that they did at a price I couldn't refuse due to my issues so I didn't compare it with the other direct comparables.
Certainly much better over the Nova however.
Some folks have
NDX > SN2, others..... have a NOVA, and others..... have the NOVA > NAP 250
As Adam asked what are you looking to do?
For me I am happy with the NDX > SN2...
I did compare to the 272 > 250 DR and choose the NDX > SN2....
seakayaker posted:Some folks have
So did I, same outcome!
I just wanted to know the difference in sound quality between different configurations. For example: NAC272 + NAP250 / NOVA / SN2 /! It's not a matter of money or system configuration. I need to stream music from NAS , Internet or CD player. Previously I was thinking about NAC272 + NAP250
And then on UNITI NOVA. Now all the answers here confused me more. I am trying to understand the technical difference in the amplification of SN2 versus NOVA. Both seem to have the same inputs and amplification . Right now, I'm not referring to the issue of the streaming . Just sound quqlity
Sorry to confuse you further...but as you said it’s not a matter of money....you need to consider the newly announced streamers like ndx2. It depends where you want to end up or spend money...the 272 is a neat solution with the preamp and dac but needs a power amp. Nova is a one box solution ,will cost less than 272/250 , .......you need to listen for yourself.....to me the Nova is better than people credit it.
The Nova include a lot of technology that could become obsolete in a few years. The SN2 will retain it's value.
Gazza posted:Sorry to confuse you further...but as you said it’s not a matter of money....you need to consider the newly announced streamers like ndx2. It depends where you want to end up or spend money...the 272 is a neat solution with the preamp and dac but needs a power amp. Nova is a one box solution ,will cost less than 272/250 , .......you need to listen for yourself.....to me the Nova is better than people credit it.
...... and the SN2 is a neat solution that has a preamp and power amp and only needs an NDX (or fill in the blank) that has a DAC......
One thing that everyone agrees about is the need to listen for yourself.
I read through every NDX/SN2 thread as well as every 272/250 & 272/200 thread and there are people in each camp that loves the "sound quality." So after doing the research, listening to a demonstration, and consideration of cost, room size, source, speakers, cables, interconnects, power supplies, racks, etc...... I somehow came to the decision that the NDX/SN2 was the sound quality that was best for me.......
Good luck with your journey Sharon...... and eventually the decision you make!
Thank you all. It seems to me that there is no dispute about the quality of the SN2. If I understand correctly, does he have Class A amplifier?
SN is class AB
You can find the specs/information for the SuperNait here: SuperNait 2
My understanding of the SN2 is that it "has a Class A preamp output stage joined to its Class B power amp section." That was taken from a 2014 review of the SuperNait found here.
Sharon Kabir posted:Thank you all. It seems to me that there is no dispute about the quality of the SN2. If I understand correctly, does he have Class A amplifier?
Have you actually heard the SN2 or the Nova for that matter? Forgive me, if I come accross as rude, but you seem to be trying to make a decision purely ‘on paper’. Is a dealer audition not possible or difficult?
One general thing worth remembering about Naim boxes - the less ‘combined’ they are, the better they tend to soud.
Nova has three functions: streaming module, pre-amp and a power amp. SuperNait2 has two functions: pre-amp and power-amp. NAP250 has one funciton: power amp.
Thank you all . I think it would be best to go hear the system. Then decide. I hope the system will be able to move the TOTEM EARTH ELEMENT speakers (-;
Their recommendation is to power amplifier between 50W and 200W
selection of speaker load is the main factor here .for the majority of new customers who want a neat and modern approach . no contest uniti with a well designed speaker. sounds really impressive
Given my experience with Totem speakers and various levels of amplification, I wouldn't be expecting much from the Element Earth's played on 80 watts. Bottom line - if you're set on either the SN2 or Uniti Nova, I'd be looking at other speakers.
Nova is the latest technology and circuit desgn, dare I say watered down from the new streamers, all the others are now OLD.
Only way to know is listen, but as Adam says what's the end game. A simple sleek solution or a multi box monster setup.
The Nova is a one box streamer that's damn fine.
I would get the Nova.
With Supernait 2 you still need to buy a source.
joerand posted:Given my experience with Totem speakers and various levels of amplification, I wouldn't be expecting much from the Element Earth's played on 80 watts. Bottom line - if you're set on either the SN2 or Uniti Nova, I'd be looking at other speakers.
From UNITI NOVA page :
"All the available space has been used to provide 80 watts per channel of Class A/B amplification capable of driving the most demanding loudspeakers"
I really wouldn’t be considering the Nova or the SuperNait to drive a pair of £9,000 speakers. You are far better getting more modest speakers and better electronics.
analogmusic posted:I would get the Nova.
I don't think you can compare all-in-one Nova with supernait 2 and for example NDX as a source. I would classified Nova below Supernait 2 and NDX ... but ofcourse those units comes from different price range as well
Kacper posted:analogmusic posted:I would get the Nova.
I agree, had Nova and changed to NDX/Supernait2. The latter much much better sonically.
You can't compare.
the same thread some weeks ago: a member was driving Wilson Sasha with the Nova and was not satisfied by the sound. The dealer was advising him to buy a better power cord...!..
