NAC102 buttons and labels
Posted by: aktiv on 25 February 2018
Enjoying an olive NAC102 I've had for quite a while.  One very minor thing I've wanted to do is update the labels within the source selection buttons (for instance, source 1 states "aux" while I actually have the turntable running through it).
Has anyone done this, are there any guidelines?
Thanks!
Keith.
Posted on: 25 February 2018 by Richard Dane
Naim used to have spare sheets of labels - IIRC these used to come with the NAC52 - so it would means tracking down an old sheet. You removed the old label by lifting a corner with the sharp point of a scalpel or similar.
Posted on: 25 February 2018 by Clive B
I sold my NAC52 with an unopened sheet of button labels. Inside the pack was a small curved metal strip with rounded ends, which I assume was meant to be used to lift the existing labels.
