Rega RP10 tracking force and antiskate
Posted by: Rotifer217 on 26 February 2018
Hi, apologies in advance as this isn't specifically a question relating to Naim components, however the rest of my system is Naim and I follow this site regularly so I imagine someone will be able to answer my question. It relates to setting up my RP10. Rega state that the tracking force of an Apheta 2 cartridge is 1.75 - 2.0g and that the antiskate should mirror this. I set my tracking force to about 1.85g as I've read it is better to err on the higher end rather than have it too low. In order for the tone arm to be lowered straight on to the record I have to set the antiskate considerably lower than suggested level (about 0.5g rather than 1.85g). If I set it any higher than this the tonearm pulls towards the outer edge of the record. My question is whether this is a problem or if I should assume all is fine and just enjoy the music? By the way, the turntable sounds fantastic, never mis-tracks and I know that the balance weight has been positioned correctly.
