A thought on where best to use your posh Ethernet cable
Posted by: kevin J Carden on 03 March 2018
I’ve just had a very interesting couple of days evaluating a Chord Sarum Super Aray Ethernet cable in my system. My objective was to see if it improved on my Audioquest Vodka which runs from a switch in the wall behind my HiFi and feeds my NDS. After a day of switching back and forth I concluded that whilst the SSA made the Vodka sound relatively coarse and fruity, it just didn’t move me and the music simply wasn’t as entertaining with SSA in place.
I was ready to leave it at that and return the SSA, especially since this result rhymed with my experience a couple of years ago when comparing DIN/DIN Interconnects, SuperLumina vs Chord SSA, but being intrigued I read online some reviews of the SSA Ethernet cable, notably the one in the magazine, The Ear. This review was glowing, but also happened to mention that they thought the improvement in sound when using the cable between NAS and switch was even greater than when using it between switch and streamer. So, with nothing much to lose I tried the SSA  in place of a Chord C-Stream between my Netgear NAS and switch, leaving the Vodka on NDS feed duties.
Transformation would be no exaggeration. All the sonic ‘fidelity’ improvements of SSA, but now with not only just as much verve, but considerably more than the Vodka. Equivalent to a black box upgrade? Absolutely. At least. My Gob is heavily smacked and my wallet is running for cover..
If there’s a potentially useful message for others here it may just be to try using your best Ethernet cable running from your Server, NAS or whatever you use to store your files into the switch rather than use it to feed from the switch to your streamer. If my experience is repeatable you may be very pleasantly surprised.
Posted on: 03 March 2018 by hungryhalibut
Here’s a thought - try another Vodka between the nas and switch, before going for the more expensive Chord. I have two Vodkas and they work really well together.
Posted on: 03 March 2018 by kevin J Carden
I think I may well do that HH. Or perhaps a lower priced Chord such as a Epic or Signature. I plan to try a few before springing for SSA. If all else fails I will try to convince the dealer that his old-school, obsolete, no longer in production SSA should be very heavily discounted..
Posted on: 03 March 2018 by Obsydian
The Aray cables are superb but also compliment Naim.
Given your media is all NAS as opposed to straight streaming ala Tidal could be this be the reason. Chord do say place at the last leg, but also wherever you introduce it everything thereafter gets the Aray effect.
The cables are massively overpriced and each new product more than the last, but I cannot deny a massive musical benefit, currently looking into the Sarum T, but £2100 is crazy (I think).
My aim is to Aray everything, ethernet (done), power cable (done) and speaker cables (to do).
Posted on: 04 March 2018 by Simon-in-Suffolk
If you want to play with so called ‘audiophile’ Ethernet type cables then I would put only between the streamer and your local switch port where any such ‘effect’ on the Ethernet physical layer performance is localised... elsewhere I would use purpose built data Ethernet cables that are Cat 5e or Cat 6 certified for max reliability.
if you are not to use certified cabling then I would use managed network equipment which allows you to check for data corruption at the link layer. If you use fibre I would definitely do the same... fibre can be more vulnerable to corruption especially over short distances
By all means experiment away with fancy cabling, even home made twisted pairs which can be very effective, but do have the equipment to check for data corruption.    Although such data corruption is unlikely to be audible in media transfers because of the use of TCP, it may affect the reliability of  multicast and broadcast used by discovery methods etc.
Also remember the current Naim streamers use 802.3u, which is Fast Ethernet, supported optimally by Cat5e. You will probably find shielded version of Cat5e .. either STP, or FTP do ‘sound’ different on the streamer due to the analogue effects of varying cable characteristics carrying high frequency signals and the interfacing of those cables to attached devices.
Posted on: 04 March 2018 by garyi
Stop encouraging them Simon!
I know.. it’s tempting to be dismissive... but I try and keep an open mind... just if one is going to play.. at least do it with ones eyes open.... and when things go awry don’t blame the home router or the Naim app
Posted on: 04 March 2018 by Eloise
Simon-in-Suffolk posted:
Keeping an open mind is good... but always be careful your brains don’t fall out!
Well I replaced some home made ethernet patch leads this weekend, primarily because its not really very good to have solid core ethernet used this way. I got some Excel ethernet cables 7 quid each. Which i though was expensive, but Excel do make stuff for the long term.
Sounded exactly the same to me, so as with so many things audiophile I guess big money has to be spent.
garyi posted:
Or all cables (which work) sound the same!
Yep... I only tend to make own ‘infrastructure’ cables... I tend to buy patch leads with their moulded  connectors as they last longer being regularly connected and unconnected... I have a box of various patch leads, and I did find a particular shielded Cat 6 patch cable .. cost about five pounds from memory ‘sounded’ subjectively the most relaxed between my 3560 and my NDX.
Posted on: 04 March 2018 by ChrisSU
Simon, if you don’t mind me asking, how short is ‘short’ in this context, using multimode fibre (without attenuators)? I think I recall that there is a maximum distance of 550m quoted for these. I have a couple of runs through the house which are about 20m. Presumably those who use a pair of media converters purely as a ‘tweak’ are just using very short patch cables?
Posted on: 04 March 2018 by Gazza
I tried the Melco, Vodka from Audioquest, qed graphite, and true audio signal Cat7. At £65 for a metre the Melco takes some beating for SQ and value for money. That’s me done for now on ethernet cables.
Posted on: 04 March 2018 by SimonPeterArnold
https://arstechnica.com/gadget...s-on-the-test-bench/
You can waste your money if you like, I think I would just buy a good  certified cable. I did recently change all my cables to see if I could hear any difference, I didn't.
Posted on: 04 March 2018 by Super
I think some people have had too many vodkas.
Posted on: 04 March 2018 by Obsydian
A fibre media bridge for circa £150 with ifi smps is still a bigger bang per £.
The Aray cables just take it to another level in realism and musicality but remaining neutral in signature, but are vastly more expensive - both for me worth it.
Network issues, I had more when I was just router to streamer.
Bottom line don't knock it until you try it, or be a Naim sheep only doing what Naim do or sell (queue a Naim ethernet £1000s) the all the lovies with be all over it and swear by it.
Or maybe some us just have golden ears as they say ????
Posted on: 04 March 2018 by Finkfan
I changed a generic cat7 cable from my router to my switch to a Meicord and I could here the difference so the Meicord stayed.
Posted on: 04 March 2018 by Mike-B
Finkfan posted:
I too changed 2x Cat7 into MeiCord Cat6,  plus tried some others like AQ & Chord in the process,  the MeiCord's are keepers.      Like one or two others have said  I do keep an open mind & don't mock anything before I try it,  but I am no longer tempted to try it.
Posted on: 04 March 2018 by audio1946
Gazza posted:
same conclusion , although i never really noted any difference  ,i went for QED GRAPHITE The lot cost £80  .  thought it would be best if cable.plug and manufacturing were the same ..  all switch to servers/players the same lenght
Posted on: 04 March 2018 by MangoMonkey
@simon
Do you recommend shielded or unshielded cat 5e cables?
I find ferrites at Ethernet cable ends make a huge difference - so wouldn't necessarily dismiss fancy ethernet cables. they probably just take the ferrites to the next level.
Overpriced? Most definitely. Just like naim. :-)
Posted on: 04 March 2018 by No quarter
I have 5 ferrites on each end of my 20 dollar Ethernet cables,sounds fantastic.
ChrisSU posted:
I’d check with the manufacturer, but anything over 10 metres might be ok... but attenuators might be best.
MangoMonkey posted:
@simon
i think it depends.. if you are needing to run Ethernet cables along side mains, interconnects  or speaker cable then I can see using shielded cable will have benefits
ChrisSU posted:
Thanks Simon, as far as I can tell from the switch management, I'm not seeing any packet loss or corruption, so I'm guessing things are working OK. When I looked at attenuators, nearly all suppliers seemed only to sell them for single mode, where I guess they might be more widely needed?
Apologies to the OP for this diversion - back to posh copper cables..........
[@mention:1566878603876589]
What do you think of the cables offered from BlueJeansCables? (You could google that term). They offer data cables with certifications - 5e, 6, and 6a variations.
I happened to have my UnitiCore down with the HiFi for the weekend. I moved away from posh cables to Cat6 cables. The noise floor went up (I think), but there's more immediacy and involvement, I think...
Posted on: 04 March 2018 by kevin J Carden
My science free and therfore uninformed view is that the main factor in my reported experience is a probably very noisy envirnment for the cable tasked with NAS to switch. Here’s a pic of my ‘data cupboard’
There’s a Sky Box, Apple TV, 3x Sonos Amps +1 Sonos bridge unit (all wireless) Cordless phone Transmitter, WiFi based Rako lighting system, Satellite TV input system, Unitiserve + Israeli PS, DVD player, 17x hard wire Ethernet connections going from here around the house, 2x Netgear NAS Drives, Draytek Router and a UPS supplying it all. I’m guessing this is potentially a very noisy environment. I suspect the reason that the Chord SSA had such a dramatic effect on the sound (and contrary to the tone of the majority of replies here I promise you I am neither deaf nor exaggerating) is principally that this cable made a much better job of shielding the signal from these nasties. I’m fairly sure that the SSA is probably not the only cable that could do this, but I reckon my task now is to find an alternative cable at a more sensible cost that can do a similar job handling the noisy environment. HH may have it right with the double Vodka suggestion - perhaps even a triple or quadruple Vodka since I also need a link to my Unitiserve as well as a link from switch to patch panel, both of which operate in the same noisy environment. ????
