Would like to add a turntable, so i need stacking order advice.
Posted by: themrock on 08 March 2018
Hi,
i would like to add a turntable to my existing system, so i need a stacking advice.
Current stacking order:
Left                                         Right
Nac 252                                 Auralic Aries G2 Streamer
Empty                                     Supercap
300 Head                                300 Power
NDac                                      XPS
My first idea
Left        Right
Auralic Aries G2      ( between both the StageLine)        Turntable
252        Supercap
300 Head        300 Power
NDac        XPS
G2 on top of left, because its in a closed aluminium case, so no/ minimal influence to 252 and i can put the Stageline between G2 and turntable.
If i would leave 252 on top left, there would not be enough place for the Stageline.
Thank you
Posted on: 08 March 2018 by yeti42
My system sounded a lot better after I moved my 552 up a shelf to directly under my turntable. It was than higher than the big ps on the adjacent shelf which might be a factor but the turntable isn’t necessarily a malign influence. Maybe if your chosen table contains a lot of steel like a Lenco L75 it might be but an Elite Rock wasn’t a problem and nor is an Artemis SA-1.
Posted on: 08 March 2018 by themrock
I will be a Rega P 3, so no steel.
