Chord Chordette HD DAC and power supplies
Posted by: Peter Thompson on 08 March 2018
Kit list is as follows, in order from computer to speakers
Good to mention:
Posted on: 08 March 2018 by analogmusic
Rather than spending money on the PSU for the Chord DAC, I would buy a later DAC from Chord like Qutest.
Posted on: 09 March 2018 by Mr THX
Brace yourself for "Naim Dac sounds better...... just swap it" posts
Posted on: 09 March 2018 by Eloise
Mr THX posted:
Shortly followed by ... ever since Chord launched the Hugo everything Naim ever made (in term of digital audio) sounds broken!
Peter Thompson posted:
Chord Chordette HD DAC (Stock power supply)
My question is, will the power supply for the DAC have any real significant improvement?
To answer the question with a short answer, yes probably ... however how much would you be spending on a power supply?  I'm assuming by Chord Chordette HD you mean the DAC usually referred to as the QuteHD?  Thats been replaced 3 times now - QuteHD --> QuteEX --> 2Qute --> Qutest (which doesn't make it obsolete by any means before anyone jumps down my neck) but spending £250-300 plus on a power supply might not be good value for money.
On the other hand the newest replacement (Chord Qutest) is going to cost you £1200 so even allowing 2-300 trade-in / second hand value for the QuteHD and £250 value of a PSU you'd be short over £500 in a replacement.  Having said that even a Chord Mojo *may* be an improvement in terms of sound quality and thats only going to cost a little over the cost of a decent power supply.
The other question to examine is "what is your source" (computer)?  You may find improvement by investigating alternative sources into the QuteHD.
