Naim Nait 1 recap - Should I?
Posted by: najibs on 09 March 2018
So recently, in my local classifieds I came across an old 1984 Naim Nait 1 for cheap. The seller was a few hours away, but agreed to meet half way, so I couldn't test it. I took a gamble.
I bought the amp, got it home and am absolutely amazed at how good it sounds.
The back of the amp has a 240v sticker on the back. I'm in Canada, so I guess at some point it was converted to 110. My question is basically if I should invest in recapping it. Doing the recap would cost me more than what I paid for the amp. It would be done at the Naim distributor for Canada, so I know it would get done right. It's 34 years old. After 34 years of little use, would you send it in to get recapped? The owner said he hadn't used it in the last 7 years and before that it was only occasional use.
I love the sound as it is, but I'm not sure if NOT recapping it would cause damage in the long run. Would it? ALso, would recapping it change the sound signature?
I don't hear any static or distortion in the sound, other than at really really low volumes, there's only sound from the right channel. It's only until you get the volume knob to the 8 or 9 o clock positon that sound comes out of both channels, but the volume is still low at that point, so it's not a big deal. Is this just a design issue or is it a sign of aging? Maybe the volume knob needs some Deoxit?
Also, if there's no music coming out of it and I let the amp sit, even with the power on, and I start playing something, for the first 20 seconds anything with a lot of bass sounds a little distorted but after 20 seconds or so it goes away, and as long as music is playing it sounds fine.
So that's my dilemma. To recap, or not to recap?
[URL=http://s76.photobucket.com/user/vantecs/media/IMG_20180305_200955_zps4meq7npc.jpg.html][IMG]http://i76.photobucket.com/alb...0955_zps4meq7npc.jpg[/IMG][/URL]
