When I first got my 500, I just plopped it up top on my existing gear.
Left side: 500/NDS/552/Space/Nap300 (Turned off)
Right Side: 500 PSU/555 PSU/552 PSU/Space/Nap 300 PSU (turned off).
Maybe it was just the 500 replacing the 300, but the system was absolutely magical. This lasted a week or so. I sold off the Nap300, and along with it the cables that the DIN XLR cables between the Nap500 PSU and HeadUnit. (Those were from the 300). Newer Din/XLR cables (naim) arrived a week later as did 2x medium size fraim - one of which I've not gotten around to putting together yet.
Anyway - Just can't seem to recreate the magic anymore.
From a setup perspective - What I had up there was something that no one would recommend. I just hear stories of how the Nap500PSU is super bad - one needs space around it. And that the NDS/552 need space around them. The setup was super compromised - but was awesome. Could be that I need heavy boxes at the bottom of the Fraim - but having a turned off Nap300 to make the music sound right seems a little extravagant.
Also got new SL speaker cables + s/h SL interconnects in the mix.
Really no time to faff around anymore.
Current setup:
Left: NDS/552/Space/500
Right: UnitiCore/555/552/space/500
Cables: SL interconnect, speaker cable. Regular Din/XLRs.
Ethernet - BlueJeans with ferrites everywhere, except between cisco catalyst switch and streamer (Chord Indigo, Vodka etc - faffing around with those cables).
I'll have a dealer visit me in a couple of months...
To be clear - with current setup, the system isn't sounding bad. There's the sound one is used to vs. the 'right sound' - not even sure what it's actually supposed to sound like - or when to know to stop tinkering. :-)
No idea where to go from here - maybe just let the cables burn in a little. Maybe best bet is to let the cables burn in a little and leave it all alone. :-)
What's clearly interesting is how you can change how everything sounds just by playing with the setup of the boxes. At this point, I'd rather just take tone controls - using stacking order to change the tone is way out there...
Posted on: 18 March 2018 by yeti42
Swap NDS and 552 head units as a first move.
Are all the Burndys locked?
One step at a time if that doesn’t get it back on song.
I’d replace the SLs with what you had before next and not put them back in until you’d got the magic back without.
Further ideas...
Did you change plug order assuming you’re using a multiblock. There are two schools of thought on this, power amp first (DB) and most source first (NDS/552/500) (reverse DB) not sure where the core fits into either but these are worth comparing at some point.
ps stack order - keep the top of the 500ps below the 552 head unit, which I think you can just do if the core stays on top with the 500ps just below, then the 555ps/552ps/space, the idea is to elevate the Burndys.
I had
TT/CDX2/552/superline/500 on the left and 500ps/supercap/552/555 on the right and lost the magic, swapping the CDX2 and 552 brought it back. Further improvements were to be had but this is the one that put the magic back.
Posted on: 18 March 2018 by Darke Bear
You need to let the SL cables run-in as IMO they put the system very 'off' for a while when new. The SL interconnects start bright and nasty then mellow and fill-out at the LF - and the SL speaker cables the other way around, dull then open-out.
You need to let it run-in over a couple of weeks and suffer it not being right then by week three it will sound magic and you should be very pleased with the effect. Some cables take longer - my SL DIN-XLR took a few more weeks before I was really happy with them; the only reason I kept some measure of cool was that I'd heard my Dealer run-in cable on home-demo and they were sublime.
If you have had the cables in the system for more than two weeks of use and things are not sounding right then that is where I'd look at if there are other problems.
The SL cable loom does let a lot more low bass come through so system set-up if you have large speakers that can do that bass becomes a bit more important to get right too.
DB.
Posted on: 19 March 2018 by Ardbeg10y
Good morning to you! No sunshine here, but it's not raining either. I have sort of noticed that the word death doesn't enjoy top popularity on here. May I try to reword my thoughts? If it's such a wonderful day over there, what are you doing at the computer? Go out! I have a nasty headache and some thoughts of my own, but you seem happy as a bird, so..
Enjoy
Max
I was not really happy. I had to deliver a piece of software which I've been pushing forward for weeks and is more boring than doing an harmonic analysis of a Mozart piano piece, listening to a class full of female traverso students, or see Marlyn Monroe talk in a movie. Your post was a good reflection of my motivation. Decided to write the opposite to drag myself out of misery.
I wish I had the time to take a walk.
Hope you are feeling better, I do by now.
Sorry to Mango for being off topic, but we all know that your issue is a matter of time (what not by the way).
