Will my Mu-So Qb from the U.K. work in the United States?
Posted by: Rich Mc on 20 March 2018
Hope somebody can help.
I am moving to the US for a year (Boston) and whilst I am putting my main Naim system into storage I wanted to take my Qb with me and wondered if it would work directly from the US mains voltage.  I read that there is a Switch Mode Power Supply incorporated, does this mean if I put a simple socket adaptor on it then I’m good to go.
Any experience with this is very much appreciated.
Posted on: 20 March 2018 by Gazza
Best to call Naim
Posted on: 21 March 2018 by blythe
A quick forum search reveals will work fine  https://forums.naimaudio.com/to...muso-qb-dual-voltage although, as per above, you might prefer to contact Naim for the "direct from the manufacturer" answer.
