The Great Ethernet Showdown 2
Posted by: Bryce Curdy on 20 March 2018
Perhaps unsurprisingly, my original post appears to have been deleted (unless I've missed it).  Not surprising to me because it got hijacked by a collection of several selfish self indulgent individuals who had never listened to the cables in question and therefore had absolutely zero to contribute to the debate.  These individuals can feel free to start their own post about their scientific supremacy, but leave me and the rest of us who trust our ears in peace.  Perhaps the mods could sort this out.
So in my home today listening with an Atom and Totem Tribe In-Wall speakers (second system) we went from bog standard CAT5 to Chord Epic to Chord Signatue to Chord Sarum T.  At this point we kept the Sarum T from Atom to home network and used the Signature to connect the NAS to the home network.  And then we reverted to the original bog standard for both.
There was a clear and broadly speaking roughly similar improvement as Epic, Signature, and Sarum T were substituted.  With the standard CAT5 the Music sounded somewhat muddled which Epic resolved .  Signature added fluidity and effortlessness, and Sarum T simply raised it all again in every way.  Dealer and I agreed that any improvement adding a posh cable between NAS and network was very marginal.
So my head says Signature, and my heart Sarum T.  Definitely better (although Signaure very good), but one posh cable rather than two+ Is something I can afford, or I suppose Shoreline is an option for the NAS.
PS If I follow correctly there was some sort of challenge submitted.  Subject to agreeable conditions etc I am 100% up for it.
Posted on: 20 March 2018 by Alley Cat
Gosh, where has that thread gone?  Lots of useful info there.
Posted on: 20 March 2018 by Dave J
In total agreement with you Bryce. No doubt this thread will be driven the same way those who know their science.
Posted on: 20 March 2018 by French Rooster
i hope also there will be no pseudo scientific writers here, who will try to convince us that we can’t trust our ears.   Lan cables have the same importance as interconnects, power or speakers cables.  I have any doubt in it.
Posted on: 21 March 2018 by Bryce Curdy
French Rooster posted:
The debate was perfectly healthy but not IMVHO in this thread.
Posted on: 21 March 2018 by hungryhalibut
It’s interesting that you found little difference changing the cable between the switch and the Nas. I found that it was easily heard and pretty much as big as that between streamer and switch. I use AudioQuest Vodka cables, which are a step down from the Chord offerings. I’ve had them over a year now and have basically forgotten about them. One thing - and this is not to divert the thread - when I later swapped the little Netgear switch for a used Cisco, the improvement in sound was greater than that from the posh cables - so £50 against £500 or so in this case. So if you don’t have one, you should get one. Perhaps the switch only worked so well because the cables were already in place - I don’t know. Certainly, with cables and switch in place, the musical flow is much better, and using the wussy description I’ve used before, it just sounds nicer.
Posted on: 21 March 2018 by Gazza
To follow on from HH, i found whilst experimenting with cables the improvement diminished after I installed a Cisco switch. In the end I settled on Melco cables which are about £70 or so for a metre. I could still hear the effect of say AQ Vodka, but thought the Melco had the right balance, it’s also very flexible. Bottom line wish I had got the Cisco a year ago. Now between Core and Nova, upnp or Spdif makes no difference, before I preferred Spdif cable for SQ.
Posted on: 21 March 2018 by Peder
Hungryhalibut posted:
Hi HH and others ????
Interesting,a friend has Linn's toplevel system....all new Klimax-products and 350 exakt/katalyst-speakers. Only Audioquest Vodka  in his system,even to the speaker. Cisco 2960-switch of course ????????.
He says,....on a scale from 1 to 10......10 is the best. If we put AQ Vodka between switch and streamer, and we say it's a 10 in SQ.
So the AQ Vodka between switch and Nas in his system,he think it's around nr 5 in SQ.
And the AQ Vodka to the speakers,he says around nr 4,..... maybe up to 4,5 in SQ.
You HH, say it's almost the same big difference between Nas-Switch as Streamer-Switch in SQ.
And Bruce Curdy, hear very little difference between Nas-Switch in SQ when changing the cable.
The difference we see here,is it because of the quality of network-solution or.....❓❓
Thanks to HH and Gazza - interesting.
My home network is a little complicated - my house is a new build with over 20 data points spread around various rooms (approximately 8 used) with a largish Netgear switch in my garage beside a data panel.  The switch is connected to the router and is then 'patched' to the appropriate socket on the data panel which corresponds to a particular data point in the house.  My NAS is in my study and connects directly to a wall data point.  My Atom is in my lounge and connects via a small Netgear switch (I have other network devices) to another data point although I do have the option of a direct connection to another data point although this would require a cable length >0.75m.  Food for thought.
Posted on: 21 March 2018 by docmark
Forgive my ignorance, but what exactly is a switch?   The fibre optic box coming into the house is connected to a router given to me by my internet provider.  From there, I have it connected by an Ethernet cable (nothing fancy) to an Apple Extreme, running into the WAN connection (?port).  From there, I have two Ethernet cables going to my Core and 272 from the LAN ports.  It all seems to work.  Am thinking of trying better Ethernet cables.  So - what is a switch and where does it go?  Does it replace something I already have?
Thanks.
Posted on: 21 March 2018 by French Rooster
docmark posted:
Thanks.
the switch is like your router, with ethernet imput.....but is better to separate audio from the router with phone and tv also. So we use a dedicated switch, like netgear gs105, connected by a lan cable to the router. The nas and streamer are connected to this switch: so dedicated switch.  The sound is better....
Got it.  Are there better grades of switches?  The netgear gs105 is quite cheap - $34 on Amazon.  In your opinion, is there something like an audiophile grade switch?  Does that even exist?
Posted on: 21 March 2018 by Peter Dinh
I am using an old Apple Airport Extreme as a switch, and I think it is as good as some expensive Cisco switches.
Posted on: 22 March 2018 by hungryhalibut
Docmark - I’m assuming you are using your router provided by the internet company as a modem. If the fibre box is the modem and the router is being used as a router, with the AE connected you’ll have two routers, which is not a good idea.
Anyway, we use an AE as router, and it’s connected to the Virgin Media hub set to work as a modem only. We connect from the AE to a Cisco 2960 8TC-L using AQ Cinnamon. We then have two AQ Vodkas connected to the 272 and the NAS. Using the switch like this means there is a direct link between Nas and streamer, so the music is unaffected by other internet and network traffic. The AE includes a switch, but a dedicated switch is better at doing switchy stuff than a router is. That’s about as much as I understand, which is not much, but it does work well and sounds good too, which is what matters.
Posted on: 22 March 2018 by French Rooster
docmark posted:
i and some members here recommend you the cisco 2960-8tc, refurbished and factory reset on bay site.  Or you can buy new netgear gs 105 switch and add ifi power 5 v , for a total price of around 70/80 GBP.  The cisco costs around 50/70 GBP.  The netgear/ifi power i had before will sound more delicate, the cisco is more dynamic and involving.
Posted on: 22 March 2018 by Bryce Curdy
docmark posted:
FR - what's ifi power?  Googled it but all the results are for WiFi rather than ifi.
Posted on: 22 March 2018 by Mike-B
Bryce Curdy posted:
iFi iPower       just search for that exact name   you get https  .....  ifi-audio.com/portfolio-view/accessory-ipower/
Posted on: 22 March 2018 by Simon-in-Suffolk
HH’s summary is good. However if you have a modern home network router device, including  the most recent BT Homehub, the switchports built in are often as effective as standalone switches..as internally they are using pretty effective chipsets. so it becomes a choice of wiring... and often where your home router is placed is not where the centre of most of your wired network devices are... here using a standalone switch makes sense.. and can reduce the amount of Ethernet wiring required. BTW I have used the AE switchports quite effectively for home network use... but only for devices close by it, but I have not used to connect to my streamer so no views on SQ.
Its worth remembering many home network broadband ‘routers’ are actually a combo of modem, router, Wifi access point and switch built into a single box...
By AE I am referring to AirPort Extreme rather than Express. Sorry it wasn’t clear.
MangoMonkey posted:
docmark posted:
If you don't want to go down the Cisco 2960 route (buy used for around $50), you should consider the Cisco branded (maybe it's really linksys)  SG110D05NA or the 8 port version.
The Netgear consistently make the music sound a little hot on the top-end - a little too bright etc.
I would question this. By all means use the Catalyst family of switches made by Cisco as many have found they have improved ‘things’ with their Naim digital audio... if not then different switches will perhaps bring differeing benefits if at all... it’s not really a brand label thing.. you might find a Belkin, Linksys, Netgear etc works for you. Certainly you can’t assume any device with Cisco badge on it, if not a Catalyst,  brings the benefits that many have discussed on the forum... it may bring its own benefits but is as equally likely as a particular Belkin etc...
Posted on: 22 March 2018 by Gazza
I had to put a stake in the ground and compared to a Melco 0.5 m switch to Uniti Nova. AQ Vodka, Cinammon and True audio signal all sounded different, in the end I chose another Melco to complete the link between Core and Nova via Cisco switch. I am retired, it was fun, you should treat as a fun journey, take on the advice and make your own mind up.
Bryce Curdy posted:
docmark posted:
go to amazon and tap ifi power 5v....
Posted on: 22 March 2018 by Peter1480
I also liked the Melco. It has plastic RJ45s where as others such as Chord have metal making an earth via the shield I think. I'm not sure the streamers like that. Those types of cables sounded better/different with a plastic joiner bit between the end of the cable and the streamer breaking the earth link.
......... prepared to be shot down in flames
Monsieur Rooster,  you are very confusing,  the PSU you are trying to tell us about has a very specific way to print the company name & the component.    iFi iPower,   iFi is the company & iPower is the component
Posted on: 22 March 2018 by garyi
I think there has to be a balance struck between 'sound quality' and modern usage where switches are concerned.
Personally speaking I would want gig speed switches in my network. Whilst naim streamers may be on old tech where nics are concerned, there is plenty of stuff probably on your network right now that will benefit massively from gig speed switches.
Mike-B posted:
i am not confusing i think.  Bryce Cundy could not find ifi power on google tap. I indicated him to tap the same on amazon, he will find it easily.
