NAC552 adds Vinyl experience to everything !
Posted by: rjstaines on 28 March 2018
My NAC552 adds the occasional 'pop' - it's just like listening to vinyl.
It all started a while back right after a DR upgrade; the pops would occur very occasionally and were almost un-noticable, but recently I've noticed they are becomming more frequent... about 2 or 3 an hour. They only appear in the left channel, never in the right. They don't seem to be volume dependant (they sound the same velume level whatever the volume setting on the 552, I think! )
You may ask how come I've noticed the recent increase... I've been laid low since the end of January with some (so far undiagnosed) affliction that causes abdominal pain - the kind where you want to curl up in a quiet place and try to get comfortable (or die)... and guess where the quiet, comfortable place is in our house... the lounge where the audio gear is.
The other contributing factor is the arrival of the ATC SCM 100 active speakers and the departure of the NAP500, so the power amp, which I had previously suspected, is now out of the loop, leaving just the pre-amp.
So, has anyone else experienced this unwanted 'vinyl effect' - 'pops from the pre' ?
Roger
Posted on: 28 March 2018 by feeling_zen
Pops via headphones also?
Posted on: 29 March 2018 by Gavin L
Roger, sorry to hear that you are unwell, hope things get sorted soon.
I too have been dealing with a “pop”, it seems just like yours, but affecting both channels (I think). After a lot of investigation, taking different components in/out, I am pretty sure it is the SupercapDR/SNAXO. (If you recall I have a 552 in an active set-up, so there are a lot of combinations).
We plan to swap the Supercap in order to be absolutely sure.
Not sure what component is failing. On the positive side, I have noticed any impact on the sound quality.
Best,
Gavin
Posted on: 29 March 2018 by Richard Dane
Roger, sorry to hear you aren't feeling good. Are you sure it's not something else that is causing the issue and is being "picked up" by the NAC552? A Faulty thermostat or fridge maybe? Or perhaps something else entirely?
For example, I have had an issue of a kind if low level rustling noise on one channel of my Superline. Hard to pick out at first, and initially I thought it might the a bad cap or something - but of so low a level that i thought no point in fixing just yet. However, I did some tests and it appears it may be related to my iPhone being in the vicinity. If I keep my iPhone well away from the system then no problem. But if the iPhone gets in the vicinity of the system then sometimes I get the "rustling cap" noise.
Posted on: 29 March 2018 by The Strat (Fender)
Roger - most important get fit soon.
Ditto what Richard said my system used to pop when the boiler kicked in or hob was ignited. Dedicated radial spur fixed it.
Best regards,
Lindsay
Posted on: 29 March 2018 by james n
Roger - one other thing to add to the all the excellent advice already mentioned.
You seem to have a lot of kit plugged into the 552. You don't mention if the popping occurs with all sources or just specific ones. If it's all sources, then one thing that might be worth trying is removing some of the sources from the 552 just to simplify things and see if the problem goes away. If it does, then start to plug the other sources back in until it comes back and then troubleshoot from there.
Hope you are feeling better soon.
James
PS - If you have the 552 connected via the RC5 connector for system automation, try unplugging this first...
Posted on: 29 March 2018 by Simon-in-Suffolk
Roger - I hope you get better. I agree the occasional pop from the 552 is most likely a spike on the mains from a switch with a suppressor that has gone faulty and open circuit - such as from a thermostat in a fridge or heating system.
S
Posted on: 29 March 2018 by TOBYJUG
Could the pain be a hernia from shifting those big speakers ?
When I had pops I noticed it corresponded with those times the heating or water went on. Turned out to be a dodgy timer.
Posted on: 29 March 2018 by JRHardee
In my case, it was a fridge cycling on and off.
Posted on: 29 March 2018 by MangoMonkey
My Nac552 starts beeping when a XBOX One is close by. Not so much beeping as sort of making a fax kind of whistling sound. Like it's picking up a radio station...
Posted on: 29 March 2018 by rjstaines
Thanks for all your comments gents. You've given me a few things to investigate that I hadn't thought of before. And thanks for your good wishes health wise.
Right now it's Thursday evening. I've had nil by mouth, except water, since an early breakfast - I'm half way through the preparation for tomorrow having a camera placed in places Alhazen (the inventor of the camera obscura) never dreamed of having his invention placed. Happy days
Roger
Posted on: 29 March 2018 by Eoink
All the best for tomorrow!
Posted on: 29 March 2018 by Mr Underhill
Roger,
Hope it goes smoothly .....and, they determine what is going on.
Posted on: 29 March 2018 by nigelb
Posted on: 29 March 2018 by Gazza
I had that unfortunate experience quite surreal, waiting around for an hour or so watching pretty nurses running around. Then they are the darlings helping you through this experience........they were just professional and very human.
I hope it goes better than you expect, it did for me.
Posted on: 29 March 2018 by Bert Schurink
Wish you well. I hope the advises before have given you enough clues.
Posted on: 29 March 2018 by Willy
Got DBLs last year.
Go "under the knife" on Saturday.
Coincidence?
Willy.
Posted on: 29 March 2018 by dave marshall
Aw ra best Roger, hopefully you'll be recovered in time to make it to the Doubletree on the 14th. / 15th.
Posted on: 29 March 2018 by Tony2011
Get well soon, Roger, whatever it is.
If I miss it, I'll be really ill
Posted on: 30 March 2018 by Richieroo
I was watching Paul McGowan youtube feed (PS Audio) and he recounted an interesting discussion with Arnie Nudell .... he demoed a really good preamp in a revealing system against no pre amp and direct ..... the preamp won hands down ..... I think the 552 does something similar....
Posted on: 30 March 2018 by stuart.ashen
Roger and Willy, I hope you both get better soon.
I had pops due to a Sky Q box being fitted. It turned out that it uses Ethernet by mains. Turning of the small Q units cured the problem. Might be another possible cause for consideration?
Stu
Posted on: 31 March 2018 by Simon-in-Suffolk
As an aside Sky Q only uses its internal powerline adapters via the mains if you set it up that way... always set up or have set up using Ethernet or if you need to Wifi... but never it’s internal powerline adapters if you value your Naim audio (and other audio and radio)... we use Ethernet here and the Sky Q mini boxes work a dream without any noise on the mains with whines, fuzz, hiss, clicks and pops on the Naim. I shudder to think how it would mangle my 552. Keep your mains clean... KYMC
Posted on: 31 March 2018 by stuart.ashen
Thanks Simon, good to know. I just leave the mini box off as it is barely used. Pops were mainly via the Stageline which was recently replaced with a Urika that seems to reject noise much better.
Thanks again,
Stu.
Posted on: 31 March 2018 by lyndon
I’ve had my 552 for 5 months now, it’s an amazing pre-amp, adds a totally different level of detail and refinement over the 52
So; my question is, why would you listen to anything other than vinyl with a 552
Lyndon
Posted on: 01 April 2018 by perttu
Hi Roger!
My Marantz amp had a similar symptom. I bought it during winter and placed it in relatively tight space in my tv-stand. All was well until spring came and room temperature got higher. Amp suffered from the increased heat and was noticeably warmer than before. I moved the amp to enable maximum ventilation around it and popping was gone.
Allthough different brand and pricerange.
Could this popping have something to do with amp overheating?
