Speaker cable
Posted by: Antonio1 on 01 April 2018
Hello and happy Easter to you all.
Seeking advice for a budget cable..
I ve so far concentrated on
Tellurium q black 2@54 pounds x metre
Naim naca6  _pice not available atm.
Should i stick with naim or try tqb? Thanks
Posted on: 01 April 2018 by Mike-B
It would be useful to know what your system consists of,  amp & speakers especially as its a speaker cable question.
Posted on: 01 April 2018 by Antonio1
All Naim..
............   err not very helpful,   why not list the model type/numbers.     All Naims amps are happy with NACA5 but its not so easy with other cables.
Posted on: 01 April 2018 by Ardbeg10y
Nac A6 is a nice upgrade over A5 - I assume.
Posted on: 01 April 2018 by Perol
Nac A6 is newly launched today
TQB is a great great cable in most combinations, get a used run if possible
I would choose Witch-hat Phantom over A5
Above , I would not say any of these are budget cables
Posted on: 01 April 2018 by Joppe
If you have or can track down some NAC A4 I understande the 4.1 upgrade is awesome!
Posted on: 01 April 2018 by GraemeH
Perol posted:
That’s probably about right, given that it was first announced in 2007:  https://forums.naimaudio.com/topic/naca6
Posted on: 01 April 2018 by Huge
Hitch Wat Fandom perhaps?
Posted on: 02 April 2018 by wenger2015
TQ Black is excellent, prices are exceptionally good due to many upgrading to the TQ Black 2.
