Kind of Blue....Cello?
Posted by: Smithfire on 02 April 2018
Is there an uncredited cello on the outro of side 1 on Miles Davis Kind of Blue?
Clive
Posted on: 02 April 2018 by AndyP19
Do you mean around the 5.20 mark on the track Blue in Green? Sounds like Paul Chambers' double bass.
Posted on: 02 April 2018 by Smithfire
Hmmm...being played with a bow?
Posted on: 02 April 2018 by GraemeH
Smithfire posted:
Yes - Get some of his solo’s (Whims of Chambers) to hear more extensive bowing!
Ahh, thanks guys. Mystery solved.
Clive
Posted on: 04 April 2018 by Massimo Bertola
Smithfire posted:
Yes. Unless you learn to play it by ear and pizzicato only, when you study the double bass you use a bow. If you study it.
Posted on: 04 April 2018 by Smithfire
Thanks guys....You learn somthing new everyday!
Clive
Posted on: 04 April 2018 by AndyP19
Are you Dazed and Confused ?
https://www.youtube.com/watch?v=AIHabvURnpk
Ha ha. That DOESN'T suprise me!
