. I found a used pair of 5 meter Super Lumina cables with banana connects at both ends. Is it possible to have the speaker side converted into spades,
would it be abvisable to have it done in Salisbury...... ? Thank you .
Posted on: 04 April 2018 by Adam Zielinski
SuperLuminas come pre-terminated at the factory.
I’m a little bit surprised your speakers cannot accept bannana plugs....
Posted on: 05 April 2018 by Richard Dane
Zoot, as PCD advises above, your best bet is to contact Naim's service dept. or your local distributor and ask them if it's possible to have the Banana plugs at one end changed to the spades.
