Qnap setup advice
Posted by: ted_p on 13 April 2018
Hi over the past week my qnap HS-251 has started giving me a lot of problems accessing my music.
Last night i reset the nas back to factory default settings, before i copy my music from my backup to the nas i was hoping the forum members can  give me some advice with the configuration.
With the latest updates to the QTS operating system, it keeps asking me if i want to setup "snapshots"  i think this is similar to Apples time-machine, so the question is should i turn this on, any guidance would be gratefully received.
Edward
Posted on: 13 April 2018 by antony d
Ted I use a QNAP HS 210 - what software as you using to control the UpNP? - I use Asset
I find with all the QNAP upgrades i go in and manualy turnoff the other Apps running to be honest, I only use the NAS for music,
Posted on: 13 April 2018 by ted_p
antony d posted:
Asset 6.0
i use the nas only for music.
Edward
Posted on: 13 April 2018 by Harry
I wouldn't bother.
I vaguely remember coming across this after a FW update.
If you didn't need it before you won't need it now. And IIRC it allocates HDD space to the process, thereby lowering the storage capacity?
Posted on: 13 April 2018 by TallGuy
I wouldn't bother either - I got that message when I updated the softwae on mine; it is generally something useful if you are creating virtual machines on the NAS - it allows you to instantly switch back to a previous configuration of your VM, should you break it in some way. I'm not familiar with Time Machine, but I believe it's a similar concept.
As you mention you have a backup you obviously do keep them  so you don't need to try to use snapshotting to do that for you.
Posted on: 14 April 2018 by ted_p
Hi sorry for the late reply had to go and visit a friend ho was taken into hospital. Thanks for the guidance, I have reconfigured my nas and (with snapshot turned off) and are now copying my backup to the nas (3 TB worth of music).
Again thank you for all your help.
Edward
