No BBC Statons On iRadio
Posted by: DWootton on 16 April 2018
I’m not sure if I’m missing something obvious, but I only have BBC 6 Music on my iRado list, non of the other BBC stations, national or local, appear.
how do I add them?
thanks
Danny
Posted on: 16 April 2018 by ChrisSU
You shouldn't need to add them, you should just be able to browse them in the iRadio input menu. There is even a section for BBC stations in the menu (at least for UK users.) There's something very odd going on if you can't see these options.
Posted on: 16 April 2018 by DWootton
Hi
user error, I have now found them,  I was in a genre section and therefore couldn’t see them
doh!
Easily done! Maybe save then as favourites so that they appear on the app home page, them you never need to go into the iRadio menu.
