552 Din to Din
Posted by: Richieroo on 24 April 2018
Hi just a thought - my 552 has a din to din cable that connects to PS .... the signal cables then leave the PS to power the power amp.......... has anyone tried upgrading this cable - is there a super lumina that can be used to connect????
Posted on: 24 April 2018 by james n
This cable only carries power for the control circuits inside the 552 from the PS. Signal is going via the Burndy. IIRC  I take it you have the Din-Din cable running close to the Burndy ?
Moderated Post:  James, I have edited your post so it complies with forum rules.
Posted on: 24 April 2018 by Richard Dane
As James says above, the SNAIC5 only carries power for the control and logic circuits in this instance.
Also, please note forum rules with regard to discussion of unauthorised modifications, which includes non-Naim "SNAICs", Burndy cables etc.. , Thanks.
Apologies Richard - I forgot the power carrying rule !
Posted on: 24 April 2018 by Richieroo
Hi can you clarify were the Din to Din should run ......... should it be kept well clear of the burndy cable???
Posted on: 24 April 2018 by Nick Lees
In parallel with the Burndy.
Posted on: 24 April 2018 by Dave J
Form a loose loop with the Snaic around the Burndy - try 2-3 "coils", and it shouldn't be tight
Posted on: 24 April 2018 by Huge
It's not a constrictor SNAIC!
Run the SNAIC parallel alongside the Burndy, but, if possible, not touching.  If this isn't easy to achieve then you can loop it over the Burndy cable once, twice max.
Posted on: 24 April 2018 by tonym
Try this interesting experiment - put on some music, then whilst listening gently squeeze the Burndy and SNAIC together where they enter the 552. Listen again...
Posted on: 24 April 2018 by hungryhalibut
You’re going to need really, really long arms.
I’ve heard the benefits of proper cable dressing (because an astonishingly nice man from Cymbiosis stripped everything down and did it for me once), but blow me down if it isn’t impossible for an ordinary mortal with a six tier double width Hutter rack filled to the max with wires that entangle themselves while your asleep to keep things “proper”.
As I recently re-installed the 552 and 500 I’ve done my best, but trying to keep the Burndy and Snaic parallel while at the same time inserting dressing (cough) all six inputs to the 552 would tax The Elongated Man.
Plus I ran out of swear words.
I will double check to see whether I dress to the right or left!!! Cheerz
