A review of Mu-so
Posted by: Pauly B on 01 May 2018
Here is a detailed review of the two Mu-so all-in-one music systems.
https://www.rateyoursound.com/...less-speakers-review
"Is Naim A Righteous Contender?
The Naim combines great sound quality and really elegant good looks. If you want a sound system that will look at home in your modern apartment, or your art gallery, boardroom or office then the Naim mu-so is for you.
The mu-so screams... well, it doesn't scream anything... it exudes understated elegance, fine craftsmanship, and functional good looks. We really can't stress enough how elegant the mu-so looks, and how elegant it feels when you operate its controls, or just touch the fine finish. (You might say that it's the exact antithesis of modern shiny plastic).
The sound quality is excellent....but with a few kudos. The mu-so delivers an impressive amount of room filling sounding with prodigious bass for a device its size. We also noticed that, while the mu-so sounds quite good in any location, it really excels at delivering crystal clear sound when located at or near ear level.
Since the mu-so is clearly designed to be positioned on a counter or shelf, where you can see and reach the top-mounted control panel, and which puts it at ear level if you're sitting down, we suggest that you exercise care in finding a location where the mu-so is both accessible and sounds its best. You'll find that the effort is well worth it."
