NAC 202
Posted by: Aceone on 02 May 2018
Hi could someone plz tell me what cables come with the 202 plz
Posted on: 02 May 2018 by Timo
I don‘t know but I guess it‘s on the Naim product website.
Posted on: 02 May 2018 by Christopher_M
IIRC, none.
Posted on: 02 May 2018 by james n
Christopher_M posted:
IIRC, none.
Yep - no cables and two link plugs.
Posted on: 02 May 2018 by Richard Dane
You don't get any cables with the NAC202.  You get a Narcom remote control and a pair of link plugs.
If you partner it with say a NAP200, then that will come with a SNAIC 4 for connecting to the 202.  If you decide to power the NAC202 from say a Hicap, then that will come with a SNAIC 5 to enable it to do so.  And if you wish to add a NAPSC to the NAC202 then the required cable comes already attached to that unit.
Posted on: 02 May 2018 by The Strat (Fender)
It doesn’t need any as a Naim source component will come with the requisite interconnect and a HC or NAP 200 will come with the necessary SNAIC.
Posted on: 02 May 2018 by Aceone
Thanks for your answers guys.
Posted on: 03 May 2018 by Christopher_M
It's all here: https://forums.naimaudio.com/to...-with-naim-equipment
