Classic components .... and standby...or the lack of
Posted by: Richieroo on 10 May 2018
Hi I notice with Naims new components .....commendably ... a second switch mode supply is added to allow for standby (not sure about ND555). Being the owner of a 500 system .... and having it powered all the time .... it does produce noticeable heat - which is not exactly environmentally friendly .... it seems to me that Naim really should start addressing standby in classic components....... Interestingly my NDS is the chief offender of heat output .... it is quite roasty ... so much so that when not in use - I use a little fan that blows across the case. Without the fan the NDS runs quite hot - with the fan it is barely luke warm.
