Spotify - can't contact server
Posted by: docmark on 13 May 2018
Hello - lately, when trying to stream Spotify, I've been having problems.  When I select it on my 272, I get a message which says Error - Can't contact Spotify server.  When I stream it from my iMac, Spotify works just fine, except of course I can't control it from the Spotify app.  My network seems to be working just fine.  Any ideas what might be the problem?
Posted on: 13 May 2018 by Robiwan
Naim is the problem.
Posted on: 14 May 2018 by David Hendon
Even though your network is working fine for other stuff, it may not be for your 272. As always when I get any sort of glitch, I suggest you first try restarting your 272 and if that doesn't resolve the Spotify issue, then turn off your 272 and any switch, restart your router, then when it has fully restarted turn on your switch and after that your 272. You may have to restart the app as well.
best
Posted on: 17 May 2018 by Orca901
Have you updated to 4.6? After months of stability, my Unitilite recently started experiencing persistent drop out issues with Spotify and "Please wait input initialising" messages appearing - there was a separate thread on this recently.  The drop outs appear to have been resolved by updating to 4.6.
