Avid's Vibration Platform
Posted by: Rotifer217 on 16 May 2018
I was wondering if anyone has tried out Avid's Vibration Platform  on any components and how they had found it?
Posted on: 17 May 2018 by robgr
A decent rack is the first place to start. Get a Fraim if you don't already have one
Posted on: 17 May 2018 by Obsydian
Never heard of the AVID, but in my current setup i do not want a hifi stand (i had many years of mountains of Mana) mainly due to space (i prefer a sparse layout) and must admit i have been looking for platform type support.
Posted on: 17 May 2018 by French Rooster
i prefer personally to use finite elemente cerapucks or ceraballs or similar components. They are more discrete and have great effects.  Under my turntable i use a 3mn granite platform, less cost effective than hifi market platforms.
Posted on: 17 May 2018 by Japtimscarlet
Avid are of course a well respected name In hi-fi
The platform you talk of looks straight forward enough...a light wood shelf with sobophane feet..not much to cause a problem there...unless you are trying to drain energy instead of isolate from it. So used as intended it looks fine IMO
Posted on: 18 May 2018 by badlands
It's a modern day Mission Isoplat. I used the Mission when I first started buying more expensive gear, found out that all it did was rob the dynamics from the system.
Posted on: 18 May 2018 by French Rooster
very effective anti vibration platforms are from hrs, townsend audio or finite elemente. But they cost more than 2k piece.
Thiis avid platform seems more to be a waste of money.  I can make one like this for 20 dollars...   piece of mdf wood on sorbothane legs.
Posted on: 18 May 2018 by Bob_B
I’ve had excellent results using one of these with CDS-3.
Posted on: 18 May 2018 by Oldenbroke
Four IsoAcoustics Orea 'pucks' under a sheet of glass from a hifi rack makes an audible improvement.
Tried them under a HiCap too and effect was similar. Music was clearer and more open to my ears.
Posted on: 18 May 2018 by Filipe
I upgraded my HiFi rack Akorner shelves with longer legs and bought Naim Glass, cups and balls for a little over £90/shelf. It was the best purchase I ever made. The effect on SQ was gobsmacking, even on the three power supplies. I would recommend only using three cups as Naim do with Fraim because it guarantees perfect contact of the balls with the glass, which is the whole point of the isolation as it reduces vibration.
Phil
Posted on: 18 May 2018 by Rotifer217
The finite elemente ceraballs mentioned by French Rooster look like they are worth trying out.  However, would they work with a skeletal turntable like the Rega RP8 and RP10.  I'm thinking there may be a slight risk of the turntable being knocked off the ceraballs by accident ?
Posted on: 18 May 2018 by alanbass1
I use the Audiophile Base Stratabase platform and am extremely happy with the results
Rotifer217 posted:
Naim sell plastic rings to stick on the glass over the balls that provide the security against the glass sliding off. I only bought them for the top shelves.
I have a RP10, and the Naim isolation shelf works fine. Overall the eight isolation shelves have worked a treat. Until you experience the change it is hard to believe that inadequate racks can mess the SQ up so much. It is off course dependent on each setup, so some will have more of a problem than others.
Phil
Posted on: 19 May 2018 by French Rooster
Rotifer217 posted:
unfortunately they will don’t work with rega rp8 or 10. i have rp10 myself.   They will work if the skeletal plinth is removed.   I prefer to use the dust cover, so my turntable sits on a granite platform, with good effects.
i heard that gingko platforms ( cloud) work well with rega turntables. Townsend seismic also.
Personally i use granite 3 mn base, nice looking and not cost effective.
Posted on: 19 May 2018 by Rotifer217
I am now thinking that Naim Glass, with 3 cups and balls and plastic rings to stick on the glass over the balls may be the way to go.
Rotifer217 posted:
it is nice looking and have good synergy with naim electronics. But with a turntable, i will try before.  I fear that the sound may be a bit bright....  Rega have also wall shelf, specially made for rp8 and 10.
Posted on: 20 May 2018 by Filipe
Rotifer217 posted:
Get the glass from a merchant. It’s 10 mm toughened, 452 x 400 mm, usually supplied with bevelled edges. You can choose whatever colour you like, but Naim’s is bronze. It cost me £62. Your dealer can order cups, balls and rings. TomTom and others sell online.
I can only speak of the effect with HiFi Racks Akorner. The narrower spacing if the rear legs provided the backstop. We put some 2-3mm cardboard between the legs and glass to decouple the glass from the wood and any vibration. You can tweak the position of the front cups and any time.
Experiment first before doing more. David [@mention:54786295706447945] introduced me to this solution.
Bon Voyage!
Phil
