Are hi cap and SNAPS the same box
Posted by: dolorem on 17 May 2018
This will seem an odd queation but i need to put a hi cap power supply into a fight case that i use to transport a SNAPS. Can anyone tell me if both power supplies use the same enclosure
Posted on: 17 May 2018 by Richard Dane
It depends on whether it's an early "shoe-box" bolt-down SNAPS or the later one with an extruded case.
If the former, then no, they are totally different dimension enclosure.  If the latter, then they look the same and have the same width and height, but the case on the SNAPS is shallower than on the Hicap. The Hicap case is the same dimensions as on the later NAC32/32.5/42/42.5/62 etc..
Posted on: 17 May 2018 by Japtimscarlet
Richard you really ARE a mine of information !!
Posted on: 17 May 2018 by Ardbeg10y
Japtimscarlet posted:
I assume you know that Dane stands for Definite Authority Naim Equipment?
