Album cover won't update on Atom
Posted by: Gaetanop on 17 May 2018
Looks like the album cover is stuck on the front screen on Beck's one ... Whatever the album I listen to (via Tidal) it's now virtually Beck singing :-)
Has anyone this bug too? How do I solve that? Full reset?
Posted on: 17 May 2018 by alan33
I’ve twice had stuck art (once on a NAS title, once from Tidal) and a reboot (power completely off, not just into standby) resolved it; no need to factory reset in my experience.
Regards alan
Posted on: 17 May 2018 by Gaetanop
It worked! I pushed the power button for 10 seconds. Then restarted it... and it worked.
thanks!
Posted on: 17 May 2018 by SimonPeterArnold
This bug was supposed to be fixed in 2.6 firmware are still on the old version?
Posted on: 18 May 2018 by David Hendon
From other reports it's still there in 2.6. Often these sort of glitches have more than one cause and removing one bug judt makes the problem less common. I expect 2.6.1 will do more to fix it.
best
