Naim Dac-V1
Posted by: Charles44 on 19 May 2018
Can this be used as the DAC to a CD5XS.
Posted on: 19 May 2018 by French Rooster
yes, but not sure it will be a real upgrade. naim dac into cd5xs s an upgrade....
Posted on: 20 May 2018 by J Saville
Yes you can take a digital output from the CD5XS into the Dac-V1, but as suggested by French Rooster it won't be a big upgrade. If you haven't got a power supply on your CD5XS then a Hicap DR would be the better option if you want you upgrade.
Posted on: 20 May 2018 by NickSeattle
Unless the DAC V1 is acting as sole pre-amp, in which case the upgrade factor is not a question. It works.
Are you keeping the Nait XS?
Nick
