NAC 252 Service
Posted by: John Willmott on 19 May 2018
Besides the NAP 250DR all my Naim equipment has been pre-loved.
A couple of years ago I decided the NAC 282 I had needed a service but, prior to sending it off, realized I would be without music for a couple of months so purchased a pre-loved 2002 vintage NAC 252 to take over duties in the 282’s absence.
I had absolutely no intention of keeping the 252. I was totally satisfied with the 282 .. I just wanted to listen to and experience the 252 during the 282’s absence. If the 252 was OK then I would just move it on, if it was obviously in need of a service then I would pay for a service and then move it on.
How naïve can one be ?
Even being 14/15 years old the 252 was better (yes, better) than the 282 .. it had far more heft and majesty than the 282. More detail and more musical engagement than the 282 ..
When the 282 came back from service I listened to it exclusively for a month .. but to my ears it did not rise to the level of the 252. It did have zest and enthusiasm but lacked the breadth and depth of the 252 .. so, I moved it on and actually made some extra coin over what what I had laid out for it, plus its service.
Roll the tape forward to January of this year and I’m thinking the 252 is now 16 years old and it may be time to book it in for a service, even though I had not heard anything that led me to believe that the 252 was failing at all.. AV Options booked me in for the April intake .. May delivery ..
Between January and sending it off on vacation the music from the 252 gradually became flaccid, distinctly flaccid .. the bass became bloomy and boomy, notes were fuzzy .. if ever there was a case of perfect timing this was it.
As you may have gathered this thread really has to do with the change in the 252 since it’s been back .. I will forgo the usual hyperbole and just say that there is not an ounce/inch/unit of anything resembling flaccid in this box now.
I let the 252 warm up for 24 hours when it came back and the first track I played was: ZZ Top .. Gimme All Your Lovin’ .. Eliminator.
The opening bars of this track are a quick staccato drum roll and instead of hearing a “Boom Boom Boom” as I had before the service there was a “Whack whack whack” .. taut, crisp and succinct .. wonderful.
It has just gotten better since that first track … an absolutely amazing pre-amp. And, thanks Chris West at AV Options.
