Which monitor?
Posted by: Fabio 1 on 25 May 2018
Hi all,after purchasing my Sony Ilce 7 rm3 I'm now considering a very consistent monitor upgrade,as the one I have is not in the same league of my camera.What you guys would suggest?Eizo?LG or what else?Budget being between 1k and 1,5k.Thank you.
Posted on: 25 May 2018 by Bananahead
1.5K what?
Which size?
What resolution?
What are you going to do with the monitor?
Which colour spaces are important?
NEC  DELL  EIZO
Posted on: 26 May 2018 by JamieWednesday
I have a thing about nice monitors. Your pictures will look great. But bear in mind not many other people have great monitors and to them they won’t look so great, in the nicest possible way!
I just stuck with a decent-ish Samsung for about £200 and it’s absolutely fine.
Posted on: 26 May 2018 by count.d
The NEC PA302W is very good. I would personally never buy one less than 30".
Posted on: 26 May 2018 by Bananahead
It is a NEC 272W that I use. I don't have room for a 30" - and it wasn't available when I bought mine anyway. I think that above 27" a bit more resolution is needed - so the 32" PA322UHD it is then.
However, I would go for colour accuracy over resolution.
Posted on: 26 May 2018 by Eloise
Eizo if you have the money, BenQ if you’re on a bit more of a budget.
Actually possibly BenQ regardless at the moment.
Posted on: 28 May 2018 by Fabio 1
Thank you for your replies.Bananahead,I am not a pc expert definitely, that's why I'm asking the Forum.What about your photos?Aren't you uploading on here anymore?Budget up to 1500 euro max.Ciao
Posted on: 29 May 2018 by Bananahead
Yes, I haven't posted any photos in a while. Maybe I should.
I spent a long time deciding on my current monitor. And I knew what I wanted from a screen.
I suggest that you look at 27" IPS screens with at least 99% sRGB coverage.
http://www.tftcentral.co.uk/
Posted on: 30 May 2018 by Fabio 1
Thanks a lot
