Organizing Playlists in Uniti CORE
Posted by: jGolf53 on 26 May 2018
Looking for suggestions on ways to organize playlists within the CORE.  Alphabetical? I seem to be stuck with the order being the date created...newest at the top of the list.  I do see within the Naim app NAC 272 PreAmp you can organize the Tidal playlists in Alphabetical order.  All ideas welcome.....
Posted on: 26 May 2018 by jGolf53
Additional questions - how to organize within a playlist......
Posted on: 26 May 2018 by Pcd
Not sure how to sort playlists but to sort  the order of a playlist you open the playlist and then hold on the individual track and move it up or down the list as required.
Trust this helps.
Posted on: 26 May 2018 by ChrisSU
If the playlists are viewed on the app home screen (as opposed to the UPnP input menu) I believe you can drag them into the order you want, as you can with the tracks within a playlist. As I remember, there is an 'edit' button at the bottom of the list, for this purpose, although I'm not at home at the moment, so I can't check this.
Posted on: 27 May 2018 by jGolf53
I tried that...can't get it to work and still have not figured out a way to organize the Playlist order.....order seems fixed on creation date.  I am able to move tunes around within the playlist.
Posted on: 27 May 2018 by James G
Playlists and Favourites for that matter are poorly supported by Naim's app, certainly for those of use who use the Core as a source and control. I raised reordering as an issue more than 12 months ago with support but from what I was told, usability 'suggestions' are considered by Naim directors (seems a bit excessive) and presumably they don't prioritise improving usability and customer experience over their shiny new products. Maybe raise with support, hope you have more success than I did.
