Supernait 2 + ND5 xs2 or nap200 + 272
Posted by: cuciu76 on 03 June 2018
hi forum,
what solution should i prefer? Im curious about the new naim streamers and their new features like roon ready possibilty.
thanks
Posted on: 03 June 2018 by Huge
There will be sound differences as well as feature differences.
To decide, you'll really need to listen to them both, preferably a home demo.
If you can't arrange that then a dealer demo using your own speakers is the next best thing.
Posted on: 03 June 2018 by Perol
Not many have listenend to the new ND5
Posted on: 03 June 2018 by Gazza
The new streamers will start to be on demo starting with the ND555, my dealer has an evening on a June 14 th. My understanding is that the new ND5xs2 is the last to launch this year. I would wait, these will be a step up from their previous models.
Posted on: 03 June 2018 by Bob the Builder
100% ND5XS2/Supernait2 the 272 is old and a bit stale nowadays of course you could add a £7,000 PSU to perk it up a bit but why bother.
The ND5XS was an underrated player IMO so the new version should be excellent and the Supernait 2 is also probably better than the pre of the 272 and the 200 so iy is a know brainer really.
Posted on: 03 June 2018 by No quarter
Bob the Builder posted:
I owned a SN2 before I got my 272/250 DR...and I disagree with your statement that the SN2 is better,did you OWN both?The SN2 does not have DR tech in the pre,you have to add a high cap DR to get it,which I did.Even after adding it to the SN2,it does not equal the 272/250.The SN2 was good hifi,the 272/250DR is REAL music in the room...IMO.
Posted on: 03 June 2018 by ChrisSU
No quarter posted:
Actually, the SN2 preamp power supply is DR. As for which of these various systems are 'better', I think the OP is unlikely to learn anything useful here, especially about a source component that is not yet in production.
Posted on: 03 June 2018 by GraemeH
I had SN2 NDX XPS2 and find the 272/XPSDR 250DR more musically insightful and, well, enjoyable.
If that helps.
ChrisSU posted:
No quarter posted:
Oh yes,sorry,it is the amp portion that is not DR,I had it backwards...but I did own it for a year and a half,looks like Graemeh agrees,and he owned both too,not just a quick demo,that I think a lot of people base their statements on.
Posted on: 03 June 2018 by rainsoothe
I also had the SN2 fed by Dac V1 and much prefer my 172xs + 200. So audition is the only way.
I actually stated that I thought the Supernait 2 was ' probably ' better than 272/200  not that it was better than  the 272/250DR.
Posted on: 03 June 2018 by joerand
Either way, "better" is an arbitrary term, "probably better" more so.  Comparisons and contrasts are useful to a degree, but ultimately describe one's experience with specific gear and how it worked in conjunction with their room, speakers, and personal predilections. To call one system over another a no brainer with no supporting description is meaningless.
Posted on: 27 June 2018 by photoguy
Just got my 3rd SN2 and they say third time is a charm. UltraRendu/LPS-1.2/Curiuos/Mirus, Chord Chorus Ref. Dual REL S/2 subs. 20X2L/AN-S2/Croft 25R as MM phono pre, tellurium Q black to P3s.  Finally very very happy. I run a long balanced Cable around room to the headphone rig. HDV 820/HD800S. Finally found best of all worlds.
Posted on: 27 June 2018 by SongStream
Interesting.  I find that one is enough.  Why do you need three of them?
Sorry. Sold the other two. Kept going tubes and missing what Naim had to offer. Bass grip, impeccable timing, dynamics, etc. Now I’m back. Oh, speaker cable is the latest Tellurium Q Black II model. Thinking about upgrading my Mirus to the Pro Signature Model but don’t want it to get fatiguing and think the synergy is right using the minimum phase slow roll off filter.
