UnitiServe
Posted by: Danny Turnbull on 06 June 2018
Does anyone know if Naim plan to remove AMG as a metadata lookup engine? the service is now inactive so adds another minute to each rip....
Posted on: 06 June 2018 by ChrisSU
I haven’t noticed rips taking any longer recently. Is your firmware up to date?
Posted on: 06 June 2018 by David Hendon
I also don't think it should add any time to ripping, but as Chris is hinting, if you are still on 1.7a firmware then it certainly is worth doing a firmware update to 1.7b which adds a new metadata provider that is used if AMG doesn't respond to a lookup request. And answering the question, I really doubt that Naim will do any more firmware updates for Unitiserve unless the metadata services used in 1.7b stop too.
best
Posted on: 07 June 2018 by King Size
I'm having exactly the same issue as Danny.  Pop the disc in and the drive starts up then stops dead for a minute or so while it tries to lookup the metadata on AMG before finally deciding to look elsewhere.   Definitely adds a fair amount of time to the ripping process and frustratingly, of the four new discs I tried to rip today, it could only find the metadata for one.
My UnitiServe is on firmware 1.7b.
