Why two rears on USB? Atom
Posted by: Granthar on 09 June 2018
on my Atom when I select USB it shows two rears, why?
Posted on: 09 June 2018 by ChrisSU
Are you saying that the rear USB input shows twice in the Naim app? If so, that is very odd, as there is obviously only one rear and one front USB port. If you connect a drive, does it appear in only one of the two inputs?
Posted on: 09 June 2018 by Alley Cat
Granthar posted:
Is anything attached, eg a drive with 2 partitions?
