Windows 10 UAC2 driver and DAC V1
Posted by: Fernando Ribeiro on 09 June 2018
Hi,
I thought the DAC V1 was supposed to work with the native UAC2 drivers from Windows 10 Creators Update.
With JRiver 24 X64, everything works fine on PCM.
DSD via DoP does not work, whatever the software (JRiver, Foobar2000) or laptop.
I have to install Naim Drivers.
Any help or comment?
Thank you.
Posted on: 09 June 2018 by SongStream
For optimum performance and features the DAC-V1 is best used with the custom driver provided by Naim, although as you've discovered it will work to some extent without it.  You can download the driver from the DAC-V1 product page on the main Naim website.
