Isolation Options
Posted by: Gavin L on 10 June 2018
As I wait for my 52 / SC / 250 get a much needed service, I am wondering if there is anything else I could do and not much expense to improve their performance?
They live inside a built in cupboard (low profile, so they can sit side by side in serparate sections) - hidden from display - feeding some Linn Kans that sit above on a marble shelf.  Yes, I know, it is a shame to hide them away, but the was part of the deal to keep them in the main living room.
I do have some glass shelves left over from some mana stands.  Any recommendation for isolation cups?
Quite a bit of messing around will be needed to get them into situ - is anyone doing something similar and with good result?
Gavin
PS. I cannot put the Kan’s on to stands given the room layout, but I do find the shelf arrangement works quite well as it helps add a bit more feeling of bass (which would otherwise be missing).
Posted on: 10 June 2018 by ChrisSU
Make sure the cupboard is as open as possible at the back if it has doors, those PSUs will need some ventilation.
Posted on: 10 June 2018 by S3
If you have the glass shelves then Tom Tom sell the fraim cups and balls which you could use to support the glass.
Posted on: 10 June 2018 by aznblue
Another option, dome or acorn nuts underneath the glass.
Posted on: 10 June 2018 by Japtimscarlet
aznblue posted:
That sounds like an excellent budget option!!
Posted on: 10 June 2018 by Obsydian
I am in a similar predicament, albeit my Nova is out in the open but out of the way but not on a dedicated rack. I did look into isolation platforms.
So are we able to just buy the cups and balls x3 plus some glass and we get some Fraim effect?
I assume as per a normal Fraim this setup is not child friendly in terms of knocks and pushes.
Posted on: 10 June 2018 by Gavin L
Would be interested to hear from someone who has done this.  Much of an improvement?
Posted on: 10 June 2018 by listener72
I have been very naughty and used an economical solution.
It is probably not as good as the genuine one. If you buy some nuts and ball bearings of the appropriate size I think that you can get a similar effect.
The ball bearing sits on top of the nut and allows some "movement."  I selected the two so that they fit together and the ball bearing is "free" to rotate.  The glass shelf sits on top of the ball bearing.
It certainly sounds better than just with the units on shelves.
I have also tried glass marbles in the nuts but this is not as good as the ball bearings. The steel ball bearing solution also seems better than wooden "cones."
Posted on: 10 June 2018 by Skip
Hard to recommend isolation devices for Naim.
I have been very happy with footers from Herbie's Audio Lab for everything else in my system.  We rebuilt the Verdier with it.   We used it as footer units under the Verdier.  And we used it under the ProAc D40Rs, all to very good effect.     The cumulative effect among vibrating devices is huge.
I don't know if I would dare use them with Naim, but complementary to Naim, Herbie's products are truly outstanding.
Posted on: 10 June 2018 by docmark
I use Thixar Silent Feet.  I bought them from my non-Naim dealer in Vancouver.  Expensive  - $800 for a set of four.  However, they do make a difference.  German made, good build quality.
Posted on: 10 June 2018 by Bob the Builder
I bought three non Naim glass shelves of the exact same size and spec of Fraim glass and also three sets of Naim cups and balls for about £150 to put onto my existing Hutter rack and given that I already had a decent rack and the taking into account that glass wasn't from Naim the difference was not great but worthwhile.
Although I would imagine that given yours are in a cupboard that isolating them would make a noticeable difference as always it just depends how much you want to spend.
Posted on: 10 June 2018 by joerand
I found Fraim-spec glass shelves set on three acorn nuts were a worthy improvement to my gear on a dedicated Isoblue rack. I did a lot of experimentation with iterations of different nuts types, ball bearings set on nuts, etc., before arriving at the acorn nuts. These were cheap hardware fixings, so I could afford the trial and error. Dedicated isolation cups for gear in a cupboard seems a potentially costly hit-or-miss proposition in which case I'd focus on manufacturers that offer a money-back trail period. Be sure to demo isolation cups with a height that allows for three under the gear, rather than four.
Posted on: 11 June 2018 by Filipe
Naim spec glass 452x400x10 toughened, balls and cups made a massive difference to my HiFi Racks Akorner units along with medium and long legs to separate the boxes (long on the 300 head and PS).
At £90/shelf for 8 shelves in two stacks it was well worth it as the 252 and 552 (to a lesser extent) are very fussy. It improved the 282 as well.
I would not improvise as the Naim cups have only three points of contact with the ball bearing.  It’s not about movement so the ball bearing does not have to be free to rotate. It’s about reducing the vibrational energy transmitted to the boxes.
Just having 3 point suspension ensures that the glass support lies in a plane as wood will always twist, and oak more so than most woods. So even you have spikes you can’t be sure that the spike accurately seats.
Remember that it’s your speakers that are the source of the vibrational energy.
Phil
Posted on: 16 June 2018 by Gavin L
I meant to that everyone for their contributions.  I will give the Naim cups a try once I have everything back and run in.
Gavin
Posted on: 16 June 2018 by Obsydian
Filipe posted:
Phil
The last point is one I raised in the pictures thread, many high end system picks look cramped and the rack stack right bang near a speaker, bam straight firing line, can't be good.
