Error code 315 in my Nova
Posted by: Raymond-KC on 13 June 2018
Dear members, may I know anyone encounter this code before in Uniti series? what does it mean?
It happens after restarting the machine and blocks to normal menu screen. Unplug the power line did not help.
Thanks!
Posted on: 13 June 2018 by David Hendon
I didn't recall anyone reporting this and googling Naim error 315 only shows up your post, so I strongly recommend that you call the Naim Uniti support line or take the unit back to your dealer. I suspect that it is almost certainly going to need to be swapped out for a replacement unit.
Do let us know how it works out.
best
Posted on: 13 June 2018 by Raymond-KC
Thanks for your reply. Will send it back to dealer for a check and update the group.
