sonicorbiter/roon nucleus- power off when loosing network access?
Posted by: T38.45 on 18 June 2018
I face some problems with sonicorbiter /roon...it seems, that the unit powers- off when loosing network connectivity. Can one confirm same issue? If one runs nucleus, does it has this problem as well?
MANY thanks folks!
Ralf
Posted on: 18 June 2018 by Timo
I have no clue (sorry!), but have you tried the Roon Forum? Those folks seem super helpful and fast.
Posted on: 18 June 2018 by T38.45
i guess it is a sonicorbiter problem rather than roon...but may be wrong...
Posted on: 18 June 2018 by Dambor
I use the Sonore UPnP Bridge for Roon and yes, everytime  the network falls, I have to restart the bridge through its web access
Posted on: 18 June 2018 by simes_pep
Do not have this problem - but then my SonicorbiterSE running SonicorbiterOS 2.6 (and thinks it is a mRendu) is not a typical platform - I only need it to run the UPnP Bridge, which it now does without issue.
It will be replaced by an UltraRendu running SOOS 2.6 with UltraCap in due course.
I run Roon Core through ROCK on an Intel NUC5i3, which works without a hiccup. I don't undertake any additional DSP, over MQA 1st unfold decoding of Tidal Masters or local MQA files.
You could also try the Sonore sponsored forum on the CA forum, see https://www.computeraudiophile...24-sonore-sponsored/
Simon.
Thanks for reply! I‘m in contact with smallgreen computer, they think it‘s strange that the unit switches off completely ( really power it on again)...
Posted on: 18 June 2018 by WilcoFT
T38.45 posted:
Is it actually powering off completely, or are you simply unable to connect to it?   I have a SonicTransporter and have never experienced this issue.
Powering off completely, have to power on again. I tried different power outlets as well, nothing changed...
Wilcoft, if you loose LAN connection (f.ex plug LAN), what happens?
