N-Vi....Is there a SMALL (touchscreen?) monitor that can be used with the Naim N-Vi to select and play DVD-Audio tracks?
Posted by: vintageaxeman on 20 June 2018
I have a Naim N-Vi.  It is NOT currently connected to a screen, as I use it for playing CDs.  Can it be connected to a SMALL (7" touchscreen?) monitor that can be used with the Naim N-Vi to select and play DVD-Audio tracks?
Posted on: 20 June 2018 by Eloise
How about car screens?  As I recall the nVI has a composite output?  No touch screen but no need for that.
Less than £25 off eBay.
Posted on: 20 June 2018 by vintageaxeman
Thanks for the suggestion....but I would have thought that I would need a screen on which I could SELECT areas of the image onscreen to select 'track 1' etc, or  'Extras' etc.... So in my mind a car screen wouldn't work....but I have seen touchscreen 7" monitors...please continue to make suggestions, guys...
vintageaxeman posted:
The nVI won’t respond to a touch screen though.  You’d have to use the remote as you would with any DVD player connected to a TV / Monitor.
Posted on: 21 June 2018 by vintageaxeman
Thank you for that. I had not considered that the touchscreen aspect wouldn't work! So is it just a 230v DVI input monitor that I need? Cheers!
Posted on: 27 June 2018 by vintageaxeman
Have found a small (10") monitor with HDMI, HDI and VGA inputs.... Should that be ok to use with the N-Vi just so that I can see what's on a DVD or DVD-Audio disc menu?
Posted on: 28 June 2018 by Andrew Everard
Yes, any of the small monitors available on the big South American river site should be fine for this purpose. Just make sure they come with – or buy – a suitable mains power supply, as some are designed for 12V in-car use.
Posted on: 28 June 2018 by vintageaxeman
That's exactly what I was thinking. Cheers Andrew!
