NAIT XS2 display lights
Posted by: IOW1970 on 01 July 2018
Have just returned from holiday and powered up NAIM  NAIT XS2 as usual but now find I cannot dim the display as before. As a 'newbie' I cannot claim to fully understand what has changed or indeed how to correct it. Any bright ideas would be appreciated - thanks
Posted on: 01 July 2018 by Richard Dane
You can defeat the button illumination by toggling the DISP button the remote (make sure the remote is in Pre softkey mode).  However, the Naim logo has to remain lit when the unit is on.
Posted on: 01 July 2018 by IOW1970
Thanks for your response - the DISP button on remote is not responding so how do I put it into Pre softkey mode?
Posted on: 01 July 2018 by Klout10
Make sure you press the ‘pre’ button in order to have the display button aligned to your amplifier, it might be aligned to e.g. a CD player ...
Hope this helps ...
Sorted ! - Many thanks for the advice I can now put down the manual !
