Rip failed files - How to remove them?
Posted by: Core_user on 02 July 2018
I have got rip failed files in the Uniti Core after ripping CDs. Unity Core will stop when it plays these files and annoys me. I need to disconnect its power in order to resume its function. Now, I stop listening to those albums which contain one or more failed files.
Hope to find a way to delete those failed files?
Posted on: 02 July 2018 by Gazza
My Core continues to play an album except for tracks that failed to rip. I would drop Naim an email, I presume you are on the latest firmware.
Posted on: 02 July 2018 by Core_user
Gazza posted:
Thanks Gazza. The firmware is the latest version and mine does not skip failed file. I thought Naim would read this forum and provide solution. I will send Naim an email.
No you cannot rely on Naim reading the forum, they do from time to time, but best to call or email them.
Posted on: 02 July 2018 by David Hendon
Naim support may have an answer, but you could delete an album that failed to rip properly, give the CD a good wash and careful dry and try ripping it again.
But I agree with Gazza, my Core just ignores the errors and plays the track as best it can.
best
Posted on: 02 July 2018 by Richard Morris
I had this problem on a UnitiServe. The cd could be deleted via n-Serve but would always reappear.
Richard Morris posted:
That's not the same problem!
On a Core if you delete an album using the Naim app, it does always disappear. The OP is explaining that his Core stops when it gets to a track that didn't rip properly. It shouldn't do that and you can't delete specific tracks with the app.
best
David Hendon posted:
best
We both have files we can't delete…
Richard your problem if I understand it is that with US there is a facility to delete a rip of a cd in nserve but it doesn't work for you whereas the OP's problem is how to delete some tracks from a rip of a CD in a Core without deleting the rest. Naim do not provide the facility to do this. That is why these are different problems.
best
