Ive stupidly managed to get a smear of super glue on one of my speaker grills (don’t ask). It’s hardly noticeable, although the fact I know it’s there is annoying me. Could I user a proprietary super glue remover to remove/reduce it, or would (as I suspect) make matters worse. The speakers are Kudos C20s.
Posted on: 03 July 2018 by Minh Nguyen
Acetone which can be found in nail varnish dissolves super glue, however, it may also discolour the speaker grills (you could test it on an inconspicuous area on the rear). Apply sparingly using a cotton bud to slowly soak the super glue before wiping clean. Several applications may be required. I would recommend practising on a spare piece of fabric to learn the correct technique.
Posted on: 03 July 2018 by joerand
Given your avatar I'd hope you were at least using this brand:
GregWPGibbs posted:
I'd say live with it. Fook with it and it will only become more noticeable.
