555cd door not closing..
Posted by: Harlaquin on 07 July 2018
Does anyone have an idea what's wrong or have an idea how to rectify a none closing door? The light was flashing for a while prior to the present action of no action.  I have also tried to recalbrate the door but nothing happened...
Posted on: 07 July 2018 by Nick Lees
I've had this, and nothing either myself or my dealer could do about it. They couldn't even courier it back to Salisbury as the unit wouldn't fit in the box!
Eventually I bribed my daughter to ferry it to Naim, who replaced the door mech.
Posted on: 07 July 2018 by Richard Dane
If the door button is flashing then it's an indication that it's out of calibration.  I would try re-calibrating again.
Instructions for doing so can be found here:
https://forums.naimaudio.com/t...---lid-recalibration
If you still have issues then contact your Naim dealer.
Posted on: 07 July 2018 by Harlaquin
Nick Lees posted:
Thanks hopefully it can be resolved one way or the other....
Thanks for your reply
Richard Dane posted:
Yes I will try all I can before a call the office,,,
Thank you H...
Posted on: 12 July 2018 by douglas
Had this problem about 2 years ago on an early CD555. No amount of re-calibration would fix it so back to Salisbury. I had a new door mechanism, Philips laser unit and a soft ware up grade to the then current spec.
Came back sounding quite a bit better so work involved was worth it. Well, it had to go back because of the door. The older units I understand  used plastic gears in the door and now replaced by metal.
Still a great player.
Douglas.
